I'm digitizing my VHS tapes, and my VCR only outputs left channel audio. I have done several tapes, and I would like to copy the left channel to the right on the mp4 files, so that the same sound is on both channels. I have ffmpeg setup and need help with a cmd line to fix my audio. The video is mp4, and I would like it to remain unaltered. The sound is 160 kbps bit rate and 48,000 kHz sample rate, which I would like to keep and duplicate. thanks for your help.
Thanks for the suggestion. Would you please point me to a guide to do this?
It's not important the problem be solved, only that the blame for the mistake is assigned correctly
Alternatively you use some Y coupling to clone single channel on two inputs of your capture device (and later in audio editing software you may try to add those two tracks then capture device noise may be reduced by up to 3dB - later you can compress such audio as mono or duplicate channel to made stereo.
Combine left and right channel audio in MP4
By stevet in forum Newbie / General discussionsReplies: 5Last Post: 29th Aug 2023, 11:35 -
DVD audio in Left or Right channel only fix?
By progrocktv in forum Authoring (DVD)Replies: 3Last Post: 30th Mar 2021, 17:23 -
Duplicate audio file before converting it
By Mishari in forum Newbie / General discussionsReplies: 7Last Post: 11th Jun 2020, 17:00 -
lose most audio on left ear after transcoding
By tola5 in forum AudioReplies: 6Last Post: 18th Oct 2018, 12:34 -
How to fix audio that jump from channel to channel?
By midts in forum AudioReplies: 2Last Post: 24th Apr 2017, 07:04
