Hi, my first post. I bought a Bose AV18 recently to replace an AV28 that had a broken cd/dvd mechanism. All has been well until I did the multi region hack - the unit will now play multi region dvd's however the picture aspect ratio doesn't fill the screen, almost like it is 14:9 rather than 16:9. I've tried system settings on the Bose unit & also on my TV, nothing allows me to get full screen.
Any suggestions would be appreciated.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
I found that tip on google & unplugged the unit for around an hour, it didn't change anything unfortunately.
Thanks for the reply though. -
Was there any feedback on the region-hack ? It appears that the unit no longer respects the AR flag in the disk and simply displays the storage ratio.
Since you are on the UK I guess you are now playing a US disk. The storage ratio is 720*480 or 3:2 which is quite close to 14:9
I know it does not help but region-hacks do come with inherent risks. -
I wanted to view some US box sets that I'd been viewing previously. The narrow image now affects any disc, either US or UK.
The post I read re the hack stated that it had come direct from Bose & that it had worked perfectly. I'd used the exact same hack on my previous Bose AV28 & it worked without any problems at all so I had no hesitation in using it on the AV18. Just wish I could undo it. -
If it came from Bose then surely they would sell a Region Free unit in the first place.
And hacks rarely work on all systems.
Panasonic DP-UB150 DVD Multi Region hack
By protoplasmia in forum Newbie / General discussionsReplies: 3Last Post: 6th Jun 2020, 03:58 -
Multi Region Hack for Pioneer BDP-180 Player?
By Waynester in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2019, 07:38 -
Scanning DVD/BD and display information? (audio, aspect ratio, region code)
By guy24s in forum ComputerReplies: 8Last Post: 19th Mar 2018, 01:35 -
Converting 1:85 aspect ratio to 2:39 aspect ratio using Virtual Dub
By maxgremlin in forum EditingReplies: 1Last Post: 8th Jun 2017, 23:06 -
Should a Region 2 DVD played on a multi-region Blu-Ray player look normal?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 4Last Post: 11th Mar 2017, 10:46
