    Jun 2008
    Dear all
    I have used Avidemux for a long time without issues. I have upgraded my system to 4k and since then Avidemux has been behaving strangely: it loads very slowly[ up to 1 minute! ], it has crashed many times without any other program running. I have tried to go back to an earlier version without success.
    My system specs: intel i7 12700k, 16GB memory and RTX 3060 ti on windows 11 64bits home edition.
    I know that some programs don't cope with windows 11 and I wonder whether you have had similar issues and the ways to fixt it.
    Aug 2004
    PA USA
    I'm running similar hardware, you have a substantially better video card than I do, I'm running Windows 11 and am not experiencing any issues with Avidemux.
    It's not important the problem be solved, only that the blame for the mistake is assigned correctly
    Jun 2008
    Thanks sum_guy.
    Problem solved. I have installed the very late version and it worked smoothly. Well done AVIDEMUX team!
