I have some .mp4 files that I would like to batch convert with MKVToolNix. I was wondering if there is a way to batch convert multiple .mp4 files and set one of the languages from a list of subtitles to be forced enabled as well?
	I use this simple solution:
 https://www.upload.ee/files/14453660/mkvtoolnix_batch.zip.html
 When I want to edit MP4/MVK in series of files, for example 20 MKV's I first open one in mkvtoolnix edit everythink I need and same preferences as options.json in folder where I have source MKV files. Then run .BAT file (you edit your output path) and that's it.
	Thanks.
 But for me too much "mouse clicking".
 It is much easier with .BAT if you process a batch of similar files MP4/MKV.
 If author later add some "speed-up setting" to context menu it will be much faster to work with, like in https://www.videohelp.com/software/gMKVExtractGUI
  Easy way to use mkvtoolnix as batch helpBy xonathan in forum Newbie / General discussionsReplies: 3Last Post: 31st Aug 2023, 23:36
  Batch edit with MKVToolnix not working?By Greatestguru in forum Video ConversionReplies: 1Last Post: 4th Sep 2020, 04:42
  MKVToolnix Batch Merge Videos and Subtitles, Different FormatsBy pumpysworld in forum Newbie / General discussionsReplies: 2Last Post: 25th Nov 2018, 22:16
  Batch header edit with MKVToolNix GUI?By everapt in forum Newbie / General discussionsReplies: 1Last Post: 23rd Mar 2018, 12:07
  Help for Batch Code MkvToolNix & ExtractBy alloar in forum Newbie / General discussionsReplies: 3Last Post: 5th Jan 2018, 16:42
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
