Hello,
I have a few files (2 to 3 gigs each , 4k 30fps) taken by an app (mcpro24fps, android) that are unreadable (eg. By VLC and other players, and VLC can't repair them).
I assume that I didn't finalise the videos by pressing the record button to finish the videos (stupid mistakes).
Is there a way to make them readable? Perhaps software (I tried a few windows apps though none seemed robust) or by appending the end of working videos recorded by the same app (doubt that would work).
I asked the developer who said it's not possible.
Try Remo Repair MOV. You'll need a similar good file from the same device as reference.
https://www.remosoftware.com/remo-repair-mov
You can get the full video from the free version:
https://forum.videohelp.com/threads/401078-Simple-Screen-Recorder-for-Linux#post2613625 -
Did you try untrunc? You need to feed it a reference (good) video recorded the same way/settings
https://www.videohelp.com/software/MP4-Repair-untrunc-GUI -
That's doesn't sound promising. Have you looked at it in a hex editor? Just eyeballing can often be useful,
a good file has the header, followed by the data, a bunch of random binary values.
Often files that are "lost" contain garbage or just binary zeroes
recover MP4 files
By khoelscher in forum RestorationReplies: 7Last Post: 5th Dec 2020, 19:11 -
Hex editor to recover damaged GoPro video files (Hero3)
By snooger in forum Video ConversionReplies: 24Last Post: 17th Nov 2018, 16:01 -
Best method for conversion and compression of large video files?
By Reaper4578 in forum Video ConversionReplies: 4Last Post: 18th Aug 2018, 08:13 -
"Recover"/Convert/Download Local Silverlight files to video
By enzeru in forum Video Streaming DownloadingReplies: 6Last Post: 15th Jan 2018, 03:07 -
how to recover deleted mp4 files
By _Al_ in forum RestorationReplies: 11Last Post: 31st Dec 2017, 13:47
