  1. How do I save the options under the "advanced" tab into my template?
    When I save a template now, it just saves the options under "video",
    everything else has to be reset when I go to use that template.
    It kinda defeats the purpose of having a template if you have to
    manualy turn on ghost reduction and color corrections options each time.
  2. Banned
    Apr 2001
    Calgary, Canada
    What version are you using?
    I had that problem with 12x versions, but 2.53 so far seems to save all my settings when I tell it to.
  3. Yes im using 2.53 also.
