My source is a ROKU 3 on wifi capture software is OBS.
Here is the one I bought, currently unavailable on Amazon though.
https://www.amazon.com/gp/product/B08YRWB7VD/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Results 31 to 43 of 43
It's not important the problem be solved, only that the blame for the mistake is assigned correctly
Regarding my realtime IVTC cap in post #20, I tracked the A/V sync problem down to the "decimate=5". Without that the audio and video stay in sync. Decimation doesn't normally cause an A/V sync problem (if I capture as MJPEG first, then decimate that file with ffmpeg the output doesn't have a sync error) but I guess doing it in realtime is causing something to mess up. Switching to faster encoder settings (or a faster codec) didn't help. Changing the order of the filters (crop first, decimate second should be a little faster) didn't help either. It's unfortunate since most of what I would want to capture is film based.
I also figured out how to get the levels correct without adjusting the capture device's proc amp. Here's the IVTC script with that modification:
I think the scale filter as used here doesn't actually do anything to the video, it just prevents the automatic full-range to limited-range conversion before sending it to the encoder.Code:ffmpeg -y -color_range tv -f dshow -rtbufsize 1G -rtbufsize 1G -show_video_device_dialog true -show_video_crossbar_connection_dialog true -video_size 1920x1080 -framerate 30.00 -i video="USB Video":audio="Digital Audio Interface (USB Digital Audio)" ^ -pix_fmt p010le -vf crop=1920:800:0:140,decimate=5,scale=in_color_matrix=bt709:in_range=limited:out_color_matrix=bt709:out_range=limited ^ -c:v hevc_qsv -preset:v veryfast -global_quality 18 -profile:v main10 -colorspace bt709 -color_range tv -c:a pcm_s16le output24p.mkv
I'm not certain but I believe it's HDCP 1.3Is that HDCP protected contentIt's not important the problem be solved, only that the blame for the mistake is assigned correctly
I didn't even think about my DVD's and BD's, I'm going to need a lot more storage now!I was able to capture from DVDs, BDs, and Netflix.It's not important the problem be solved, only that the blame for the mistake is assigned correctly
My capture machine doesn't have an optical drive.
It's not important the problem be solved, only that the blame for the mistake is assigned correctly -
Seriously?
You wrote "Device can supply 1080p @ 60fps (I can set it easily in ie VLC or OBS)." How was anyone to guess from your first post (as originally written) that 1080p @ 60fps is not a resolution and framerate you believed this device would be capable of delivering in its captures?
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
No idea what you mean, but I do not care for this device, or it’s capture abilities
I use it mainly as a “monitor” for RPi
It was fun to give it a go, but I have nothing to capture anyway any more (last tapes I done years ago)
But it can capture just fine (or acceptable or whatever opinion one might have)
If one wants something better this could be an option (10x + the cost)
http://www.tystvideo.com/en/product_detail/172/411.html
Honestly I had simply no idea where to set the options in VD2 (last time I used VD was a decade ago)
Hence the thread is solvedLast edited by sebus; 24th Feb 2022 at 08:39.
chinese usb 3 device capture
By codebox in forum Capturing and VCRReplies: 28Last Post: 21st Jul 2021, 16:20 -
What is a good USB Capture Device to use with VirtualDub?
By anachronon in forum Capturing and VCRReplies: 12Last Post: 2nd Mar 2021, 17:56 -
Out of touch with video capture - USB capture device advice
By Lambchop in forum Capturing and VCRReplies: 7Last Post: 25th Nov 2018, 05:19 -
Firewire / USB / Capture device
By GovertdeKat in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 23rd Nov 2018, 12:01 -
Device not detected on VHS to USB Capture-Converter
By Anonymous754 in forum Capturing and VCRReplies: 10Last Post: 26th Jun 2017, 07:46
