    Feb 2022
    I have a video on an MKV file that, when displayed on TV or any video player (including VLC Player!) shows a very small screen and is surrounded by thick black borders. I would like to resize the video display so that it will be the proper size for TV or any video players without the borders.
    There seem to be a lot of converters (free and otherwise), but none of the ones I found will actually resize a video. There are plenty of tools that apparently let you shrink a video so that it will work with mobile devices and screw around with aspect ratios, but what I need to do is to increase the size of my video so that it will actually fit the screen(s) that I play it on.
    Can someone point me to a tool that will do this?
    Thanks in advance for any suggestions.
    canada
    Load the video into vidcoder,it should detect the black borders and remove them when you re-encode the video.
    Mar 2008
    Netherlands
    In mkvtoolnixgui you can change the aspect ratio of the movie?
  4. users currently on my ignore list: deadrats, Stears555, marcorocchini
    canada
    Upload a short(10sec)sample of the video here so we can see if the video has the black bars baked in or just flagged that way.
  6. As johns0 wrote, we need your support.
    Load your mkv into Avidemux, cut after 30 seconds, save to a new mkv and post this new file here.
    So we will take a look.
