I have a Dazzle DVC100 hooked up to a computer with Windows 10 version 1511. For some reason it won't capture any sound with Pinnacle's drivers. The video is flawless. Could someone help?
What software are you capturing with?
Choose The Dazzle device audio option in VLC.
I've done exactly that and it has no audio.
Maybe you should update windows 10 cause 1511 is 7 years old.
Agreed, update to Windows 7. That works with everything.
I use this as my capturing computer. My main computer is on the latest version of Windows 10 which means the Dazzle will drop frames if I use it there.
+ I don't have a copy of 7.
Youtube-dl-gui on Win7 and Win10
By Axel Slingerland in forum Video Streaming DownloadingReplies: 9Last Post: 6th Jan 2022, 08:41 -
Pinnacle MovieBoard 500 + Win10?
By lpmaskman in forum Capturing and VCRReplies: 1Last Post: 12th Sep 2020, 13:00 -
Dual boot Win10 32 bit with Win10 64 bit
By bevills1 in forum ComputerReplies: 15Last Post: 9th Apr 2018, 17:59 -
Paint.net On Win10
By budwzr in forum EditingReplies: 0Last Post: 8th Feb 2018, 22:31 -
Win10 31.january update
By Bernix in forum ComputerReplies: 0Last Post: 31st Jan 2018, 15:27
