Can you connect a 110 volt NTSC Only VCR to a PAL TV trough RF??
And watch movie in color with sound?
Results 1 to 9 of 9
Don't think so. Virtually ANY PAL vcr will playback NTSC tapes in full colour on a PAL tv but a NTSC vcr will have all the wrong timings and colour signal.
Will use it with NTSC tapes not with PAL tapes.
I had a NTSC CED player with only RF, a PAL disc give this:
https://www.youtube.com/watch?v=ShqJmNWNw0U
A NTSC disc give only noise.Last edited by anonymoustly; 11th Feb 2022 at 18:47.
Like I said, a NTSC vcr will send the wrong colour signal to a PAL tv. At best you get a B&W picture.
One could, in the past, get standards converters which change the NTSC colour to PAL colour. Then you could use the PAL tv fully. (Still require a power adapter since I guess your voltage is not 110)
A PAL vcr will, however, convert the NTSC colour signal and playback NTSC tapes in full colour. No standards converter required and no power adapter either - maybe a change of plug but that's all. -
Can you tell/link what converters you mean?
I only know that converters for composite, not RF.
And in menu these says there is M system:
You cannot connect NTSC RF-out on the VCR directly to the RF-in on a PAL TV and expect to get a picture of any kind. The RF-out on an NTSC VCR uses NTSC channel 3 or NTSC channel 4 to provide a signal that an NTSC TV can tune. PAL TVs have a PAL tuner that cannot tune an NTSC signal.
You would need to connect the NTSC VCR's composite-out to the NTSC composite-in connection on an NTSC to PAL composite video converter. The PAL composite-out on the converter would need to be connected to the composite-in connection of a PAL RF modulator. The PAL RF modulator's RF-out would be connected to the TV's RF.Last edited by usually_quiet; 11th Feb 2022 at 21:55.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Hello, here i have a picture, direct NTSC RF on PAL TV.
Ofcourse it is not good and useless, but at least i have some identified picture. -
PAL TV's usually accept NTSC video without problems (at least you should get B/W picture), audio on RF is different topic.
If you did not use RF (let's say Composite instead) it would work out of the box with any European TV made in the last 15 years*, and with many but not all before that (with the number decreasing until you hit about 1990 where it approaches zero percent).
* well, minus the the HDMI-only ones (wouldn't ever buy such lol).
Edit: Yes, I am talking about NTSC color, not PAL60.Last edited by Skiller; 12th Feb 2022 at 12:22.
Help plz with correct way to connect VCR to A/V reciver
By vetski179 in forum Newbie / General discussionsReplies: 10Last Post: 18th Nov 2020, 19:57 -
Converting NTSC->PAL Interlaced DVD Back To NTSC 24FPS???
By SegaSonic91 in forum DVD RippingReplies: 7Last Post: 3rd Oct 2020, 00:55 -
capturing ntsc tapes from pal-60 vcr
By Imy in forum Capturing and VCRReplies: 25Last Post: 4th Mar 2020, 08:10 -
PAL SD Video capture trough audio interface?
By Axelwaad in forum Capturing and VCRReplies: 3Last Post: 5th Jan 2019, 14:02 -
Connecting PAL VCR to a NTSC DVD recorder and vice verse?
By guy24s in forum DVD & Blu-ray RecordersReplies: 3Last Post: 29th Jul 2017, 17:57
