Tried DVDFab, but it want's you to create a new menu. How do I get an original DVD9 disc with menu's, backgrounds, sound, etc converted to a BD25 disk? Thank you in advance!
Simple answer.
You can not. No authoring program AFAIK can transfer menus to other media.
Also, I fail to see your purpose in doing this. You can create a copy of your original dvd to DVD-9 with ALL features retained. -
I have the original dvd9s of the old TV Animated Series Dungeons And Dragon's. The dvd9's do not play well on any dvd or bluray player I have tried. I have even made copies and tried those, same thing. Seems like that's the case for a few dvd9's I have made. I just figured I could convert them to BD25's which play fine in my BluRay player.
That's possibly a case of using poor blank media and/or wrong burn settings - use try Verbatim media and restrict burns to half rated speed ie for 16x media burn at 8x.
Also make sure that the DVD-9 media is DVD+R DL. DVD-R DL media won't work.
Best way to convert UHD 4K to BD50 or BD25
By Jphfanedits in forum Blu-ray RippingReplies: 9Last Post: 16th Jan 2025, 11:44 -
Tricky subtitle problem -out of sync, dual episodes, but different episodes
By fireaza in forum SubtitleReplies: 6Last Post: 19th Jan 2022, 13:03 -
BD50 to BD25 best quality?
By PatrickBatman in forum Blu-ray RippingReplies: 26Last Post: 2nd Oct 2020, 17:06 -
DVDshrinker or other free soft to convert or copy DVD9 to DVD5
By algusev in forum DVD RippingReplies: 2Last Post: 19th May 2020, 15:53 -
BD Rebuilder - Best settings for a bd25 or bd50
By GTAGamesLvr in forum Video ConversionReplies: 5Last Post: 17th Feb 2019, 16:09
