I'm wanting to edit some PAL videos which are 768x576 but are registered as 720x576. When Vegas is being used it changes to 720 and everything looks a bit fatter. I've done many things to try and keep the videos as they should be by Vegas, however Vegas is always wanting to convert the videos.
What do I need to do to keep things as is?
You can create a custom project properties and set pixel aspect ratio to 1.0667 for 4:3 PAL full frame AR interpretation.
(The exact value would be 16/15, because 4/3 = 720/576 * 16/15 , but vegas uses 4 decimal approximation)
Short explanation : There are slightly different aspect ratio interpretations for "4:3" , the one vegas by default is based on the central portion that excludes pillarbars (usually some analog sources, or DV aspect ratio)
Frame Size / Aspect Ratio conversion in Vegas Pro
By Joey Bagodonuts in forum Video ConversionReplies: 3Last Post: 22nd May 2020, 14:47 -
Should I uninstall Vegas Pro 14 before installing Vegas Pro 15?
By hbenthow in forum EditingReplies: 5Last Post: 18th Dec 2018, 20:34 -
Sony Vegas Pro 13, different framerates in the same project - problem with
By SusanM in forum EditingReplies: 2Last Post: 4th Apr 2018, 15:47 -
VEGAS pro 14 + Vegas2HB - script problem
By Peter76 in forum EditingReplies: 0Last Post: 21st Feb 2018, 06:15 -
Interlace Flicker Problem in Sony Vegas Pro 14
By Isantistao in forum EditingReplies: 4Last Post: 8th Sep 2017, 09:42
