once you click ok, theres another notification saying its been copied to the clipboard though.
it probably doesnt need this line if it doesnt copy to the clipboard
thanks for the script!!Code:alert("PSSH has been copied to clipboard")
Results 31 to 60 of 75
mate, i know copy to clipboard manually work.
but your script after click OK show this:
[Attachment 63271 - Click to enlarge]
but this is not true. understand?
or add feature to copy on clipboard ...
anyway work. nice job! -
i dont hide pssh but i've hide site FROM get pssh (www.blablabla.com...)
your script generate 2 window: the first with pssh, and second, my shot above
and no, read post#31 by ElCap, pssh isn't copied on clipboard. need to copy manually.
add on your script option to copy pssh to clipboard -
i have this mpd file
[Attachment 63279 - Click to enlarge] and it contains a pssh and a kid syntax is it possible i can get the keys? -
does this method still work?
I think I followed it, i copied the base from the tampermonkey script; i used getwvkets.cc to get the key, i then used stream detector, to get the playlist; I used "yt-dlp" to download what i found in the stream detector, then i used mp4decrypt the .mp4 file, and it doesn't look decryptped. I regenerated the key, and it is different now, i tried to decrypt the file again with the new key, but it still looks improperly decrypted (cause I see gray screen and here random bytes). -
yes, this method work
about your key: try to look directly into mpd. sometime you find pssh
< I regenerated the key, and it is different now >
the lic url is the same, the only variable is pssh
but if your error persists, write here your video link -
I don't know what link
https://player.pl/playerplus/programy-online/zglos-remont-odcinki,7665 -
Oh, so tvn and player.pl is the same thing? Dude, you're in a thread with both images and video of the solution.
If you want the keys....... we'll give you.
If you want to learn :
You need two things for your site....
PSSH and Licence Url.
Luckily this site doesn't need specific headers to deliver keys.
I let you search a little bit on the forum to get PSSH and Licence url. (use search Tab in the forum)
Just a tip with the PSSH ....when you'll find it....go to this thread to have the good one
https://forum.videohelp.com/threads/404052-Help-downloading-some-videos/page2#post2655888
After that,
You can use this site to get your keys
https://cdrm-project.com/ -
I do not know if this is the key and if so how to download video with this key
aHR0cHM6Ly9wbGF5ZXIucGwvcGxheWVycGx1cy9wcm9ncmFteS 1vbmxpbmUvemdsb3MtcmVtb250LW9kY2lua2ksNzY2NQ -
Yeah, that's not the key, lol
[Attachment 70794 - Click to enlarge] -
Can anyone download for me this video? I don't know a thing about coding.
https://player.pl/seriale-online/kryminalni-odcinki,6/odcinek-89,S08E89,449 -
N_m3u8DL-RE "https://r.dcs.redcdn.pl/dash/o2/tvnplayer/vod/08_400_08195_0001/LIBCODER_SMOOTH_720_PL/aca04a8a-7b6c-4f91-8002-08ecedcf9494/playlist.ism/playlist.mpd?dummyfile=" --key 10d5a8ffdcce466a8ccfd06e1687e736:db87d12e18afc5bf66241ebeefe47c30 --save-dir "media\player_pl" --save-name "Kryminalni_Zlodziej_tozsamosci_8_89" -M format=mkv
[*drm mass downloader: widefrog*]~~~~~~~~~~~[*how to make your own mass downloader: guide*] -
Download and put in the same folder (of your choice) the following programs (if you download a zip, then search in it the right executable file):
- N_m3u8DL-RE
- ffmpeg
- mp4decrypt
Then open cmd in that folder and run the command provided in the previous post. For example if you use windows, the content of that folder should have:
- N_m3u8DL-RE.exe
- ffmpeg.exe
- mp4decrypt.exe--[----->+<]>.++++++++++++.---.--------.
Hi!
I set up the folder like this
[Attachment 85689 - Click to enlarge]
But I still don't know how to open the cmd. If you can explain me that, I'm struggling to find the way to finish this
Thank you!Best,
Artur -
In addition to what @cedric recommended, if you click on the path line "Descargas > FILES" (not on the actual text, but on the white space part on right side) and type cmd it will open it right in that folder with all your executables
How to download video from jw player 8.8.2
By ningnong132 in forum Video Streaming DownloadingReplies: 17Last Post: 7th Jul 2022, 21:11 -
need help with JW player 8.19 download
By varjakas in forum Video Streaming DownloadingReplies: 2Last Post: 16th Mar 2021, 08:38 -
Guide for JW Player Download
By Tortle in forum Video Streaming DownloadingReplies: 1Last Post: 24th Nov 2018, 10:59 -
how to download from rtmp player
By Juni745 in forum Video Streaming DownloadingReplies: 0Last Post: 14th Apr 2018, 13:38 -
download from bbc player
By Anonymous in forum Video Streaming DownloadingReplies: 6Last Post: 31st Mar 2018, 09:26
