I have a 4k mp4 on my hard drive the rez is 3840x2160 for some reason if i select matroska preset in handbrake (h.265 MKV 2160p60) it moves the rez to 3840x1600.
I do not want to lose quality. The codec of the original mp4 shows a framerate of 23.976. What are the settings I should use to not lose quality or increase size?
All suggestions welcome.
Results 1 to 12 of 12
Handbrake selects "Automatic" with values Top = 276, Bottom = 274...for "Cropping "
What does this mean?Last edited by alagupuppy; 9th Feb 2022 at 15:57.
By default the program will crop away the black. Just disable it if don't like it
It doesn't really affect the quality. Some prefer to crop. Others like keep the encoded black letterbox as a part of the video. Upon playback, should look the same. Most of the media files on my PC are cropped
If you're not planning on making a Blu-ray movie disc there's no reason to keep the black borders.
4096x2160 or 3840x2160
By therock003 in forum Newbie / General discussionsReplies: 21Last Post: 24th Jan 2023, 18:16 -
Disable default subtitle
By marco000 in forum Video ConversionReplies: 16Last Post: 24th Jun 2021, 10:55 -
Where to change default Handbrake GOP size?
By Dougmeister in forum EditingReplies: 4Last Post: 4th Jan 2021, 19:13 -
Blocking/Pixelation encoding issue from Handbrake from MakeMKV DVD source
By the1337moderate in forum DVD RippingReplies: 5Last Post: 25th Jun 2019, 08:05 -
Staxrip 'Failed to open source, try another source filter?'
By hanaluluelle in forum Video ConversionReplies: 0Last Post: 1st Mar 2017, 02:44
