How to properly mux a Magix Vegas rendered raw AVC stream?
I rendered an AVC stream from MAGIX Vegas with Magix AVC/AAC - > Blu-ray stream 25fps (plus AC3 stream separately) and I'd like to mux it into a mkv container properly.
I encountered in the following issues:
Trying to mux with ffmpeg:
first try:
after googling and trying with flags:Code:ffmpeg -i "InnistradS8_tesztrender.avc" -i "InnistradS8_tesztrender.ac3" -c copy inteszt.mkv ffmpeg version 4.3.1 Copyright (c) 2000-2020 the FFmpeg developers built with gcc 10.2.1 (GCC) 20200726 configuration: --disable-static --enable-shared --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libdav1d --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libsrt --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libgsm --enable-librav1e --disable-w32threads --enable-libmfx --enable-ffnvcodec --enable-cuda-llvm --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth --enable-libopenmpt --enable-amf libavutil 56. 51.100 / 56. 51.100 libavcodec 58. 91.100 / 58. 91.100 libavformat 58. 45.100 / 58. 45.100 libavdevice 58. 10.100 / 58. 10.100 libavfilter 7. 85.100 / 7. 85.100 libswscale 5. 7.100 / 5. 7.100 libswresample 3. 7.100 / 3. 7.100 libpostproc 55. 7.100 / 55. 7.100 [h264 @ 000001202dd24880] Stream #0: not enough frames to estimate rate; consider increasing probesize Input #0, h264, from 'InnistradS8_tesztrender.avc': Duration: N/A, bitrate: N/A Stream #0:0: Video: h264 (High), yuv420p(tv, bt709, top first), 1920x1080 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 1200k tbn, 50 tbc [ac3 @ 000001202e42a900] Estimating duration from bitrate, this may be inaccurate Input #1, ac3, from 'InnistradS8_tesztrender.ac3': Duration: 00:01:00.03, start: 0.000000, bitrate: 256 kb/s Stream #1:0: Audio: ac3, 48000 Hz, stereo, fltp, 256 kb/s Output #0, matroska, to 'inteszt.mkv': Metadata: encoder : Lavf58.45.100 Stream #0:0: Video: h264 (High) (H264 / 0x34363248), yuv420p(tv, bt709, top first), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 25 fps, 25 tbr, 1k tbn, 1200k tbc Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, stereo, fltp, 256 kb/s Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #1:0 -> #0:1 (copy) Press [q] to stop, [?] for help [matroska @ 000001202e2f00c0] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly [matroska @ 000001202e2f00c0] Can't write packet with unknown timestamp av_interleaved_write_frame(): Invalid argument frame= 1 fps=0.0 q=-1.0 Lsize= 2kB time=00:00:00.00 bitrate=N/A speed= 0x video:237kB audio:1kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown Conversion failed!
Code:ffmpeg -fflags +genpts -i "InnistradS8_tesztrender.avc" -i "InnistradS8_tesztrender.ac3" -c copy inteszt.mkv ffmpeg version 4.3.1 Copyright (c) 2000-2020 the FFmpeg developers built with gcc 10.2.1 (GCC) 20200726 configuration: --disable-static --enable-shared --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libdav1d --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libsrt --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libgsm --enable-librav1e --disable-w32threads --enable-libmfx --enable-ffnvcodec --enable-cuda-llvm --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth --enable-libopenmpt --enable-amf libavutil 56. 51.100 / 56. 51.100 libavcodec 58. 91.100 / 58. 91.100 libavformat 58. 45.100 / 58. 45.100 libavdevice 58. 10.100 / 58. 10.100 libavfilter 7. 85.100 / 7. 85.100 libswscale 5. 7.100 / 5. 7.100 libswresample 3. 7.100 / 3. 7.100 libpostproc 55. 7.100 / 55. 7.100 [h264 @ 0000021f79165200] Stream #0: not enough frames to estimate rate; consider increasing probesize Input #0, h264, from 'InnistradS8_tesztrender.avc': Duration: N/A, bitrate: N/A Stream #0:0: Video: h264 (High), yuv420p(tv, bt709, top first), 1920x1080 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 1200k tbn, 50 tbc [ac3 @ 0000021f7986a900] Estimating duration from bitrate, this may be inaccurate Input #1, ac3, from 'InnistradS8_tesztrender.ac3': Duration: 00:01:00.03, start: 0.000000, bitrate: 256 kb/s Stream #1:0: Audio: ac3, 48000 Hz, stereo, fltp, 256 kb/s Output #0, matroska, to 'inteszt.mkv': Metadata: encoder : Lavf58.45.100 Stream #0:0: Video: h264 (High) (H264 / 0x34363248), yuv420p(tv, bt709, top first), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 25 fps, 25 tbr, 1k tbn, 1200k tbc Stream #0:1: Audio: ac3 ([0] [0][0] / 0x2000), 48000 Hz, stereo, fltp, 256 kb/s Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #1:0 -> #0:1 (copy) Press [q] to stop, [?] for help [matroska @ 0000021f7972e700] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly [matroska @ 0000021f7972e700] Can't write packet with unknown timestamp av_interleaved_write_frame(): Invalid argument frame= 1 fps=0.0 q=-1.0 Lsize= 2kB time=00:00:00.00 bitrate=N/A speed= 0x video:237kB audio:1kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown Conversion failed!
Also tried mkvtoolnix. Playback is flawless, however it gives usable output BUT I find weird things in medainfo:
Also MPC-HC detects is as an 50fps file. Also I tried to set the following flags in mvktoolnix header editor: "Field order: 1" and "Interlaced: 1".Code:Format : Matroska Format version : Version 4 File size : 146 MiB Duration : 1 min 0 s Overall bit rate mode : Constant Overall bit rate : 20.3 Mb/s Encoded date : UTC 2022-02-09 18:49:47 Writing application : mkvmerge v64.0.0 ('Willows') 64-bit Writing library : libebml v1.4.2 + libmatroska v1.6.4 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference fra : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1 min 0 s Bit rate mode : Constant Bit rate : 20.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 50.000 FPS Original frame rate : 25.000 FPS Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan type, store method : Separated fields Scan order : Top Field First Bits/(Pixel*Frame) : 0.193 Stream size : 144 MiB (99%) Default : Yes Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 1 min 0 s Bit rate mode : Constant Bit rate : 256 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 1.83 MiB (1%) Service kind : Complete Main Default : Yes Forced : No
Also I muxed it Tsmuxer into m2ts which was recognized as a proper interlaced m2ts file, but remuxing it into mkv will give me the mediainfo as above.
How I could produce a fully compatible interlaced mkv file from Vegas render?
ffmpeg -f h264 -r 25 -i "InnistradS8_tesztrender.avc" -i "InnistradS8_tesztrender.ac3" -bsf "setts=pts=DTS" -c copy inni.mkv ffmpeg version 4.3.1 Copyright (c) 2000-2020 the FFmpeg developers built with gcc 10.2.1 (GCC) 20200726 configuration: --disable-static --enable-shared --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libdav1d --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libsrt --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvmaf --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libgsm --enable-librav1e --disable-w32threads --enable-libmfx --enable-ffnvcodec --enable-cuda-llvm --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth --enable-libopenmpt --enable-amf libavutil 56. 51.100 / 56. 51.100 libavcodec 58. 91.100 / 58. 91.100 libavformat 58. 45.100 / 58. 45.100 libavdevice 58. 10.100 / 58. 10.100 libavfilter 7. 85.100 / 7. 85.100 libswscale 5. 7.100 / 5. 7.100 libswresample 3. 7.100 / 3. 7.100 libpostproc 55. 7.100 / 55. 7.100 [h264 @ 00000266bc2b5340] Stream #0: not enough frames to estimate rate; consider increasing probesize Input #0, h264, from 'InnistradS8_tesztrender.avc': Duration: N/A, bitrate: N/A Stream #0:0: Video: h264 (High), yuv420p(tv, bt709, top first), 1920x1080 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 1200k tbn, 50 tbc [ac3 @ 00000266bca2b100] Estimating duration from bitrate, this may be inaccurate Input #1, ac3, from 'InnistradS8_tesztrender.ac3': Duration: 00:01:00.03, start: 0.000000, bitrate: 256 kb/s Stream #1:0: Audio: ac3, 48000 Hz, stereo, fltp, 256 kb/s Error parsing bitstream filter sequence 'setts=pts=DTS': Bitstream filter not found -
2020 is old binary. Use something more recentffmpeg version 4.3.1 Copyright (c) 2000-2020 the FFmpeg developers
https://www.gyan.dev/ffmpeg/builds/
https://github.com/BtbN/FFmpeg-Builds/releases
Why does muxing a video stream into a MKV file change that stream?
By 4L7zHhiyQO3Thui6 in forum Video ConversionReplies: 14Last Post: 11th Mar 2021, 04:45 -
Custom bitrate for Magix AVC MP4
By stantheman1976 in forum Video ConversionReplies: 9Last Post: 1st Mar 2021, 13:24 -
Rendered video brightness issue (Vegas)
By Welsh Jester in forum EditingReplies: 2Last Post: 6th Mar 2019, 07:10 -
Muxing h.265/HEVC Annex B raw to MP4 using MP4Box
By Metroman in forum Video ConversionReplies: 2Last Post: 16th Feb 2018, 08:31 -
joining elementary stream files (.avc) and muxing ac3 audio
By vorpaljim in forum Video ConversionReplies: 0Last Post: 11th Feb 2018, 18:23
