Results 1 to 10 of 10
    Feb 2022
    New York
    Hey everyone. Here is an interesting puzzle for you: I have over 200 mp4 files all shot on the google pixel 3xl phone in 4k. All of these have audio out of sync by about 0.35 sec. How could I batch fix the sync issue? HandBrake doesn't seem to be helping as in cases with various framerates.
    Mar 2008
    To get the full file info, open the file with mediainfo, put it in text view, and add the info to this thread
    Feb 2022
    New York
    Thanks so much!
    General
    Complete name : D:\PXL_20211028_174319619.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42 (isom/mp42)
    File size : 49.5 MiB
    Duration : 9 s 15 ms
    Overall bit rate : 46.0 Mb/s
    Encoded date : UTC 2021-10-28 17:43:30
    Tagged date : UTC 2021-10-28 17:43:30
    Video
    Format : HEVC
    Format/Info : High Efficiency Video Coding
    Format profile : Main@L5.1@Main
    Codec ID : hvc1
    Codec ID/Info : High Efficiency Video Coding
    Bit rate : 45.9 Mb/s
    Width : 3 840 pixels
    Height : 2 160 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 28.175 FPS
    Minimum frame rate : 3.006 FPS
    Maximum frame rate : 30.070 FPS
    FrameRate_Real : 30.000 FPS
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.196
    Stream size : 49.3 MiB (100%)
    Title : VideoHandle
    Language : English
    Color range : Full
    Color primaries : BT.601 PAL
    Transfer characteristics : BT.709
    transfer_characteristics_Original : BT.601
    Matrix coefficients : BT.601
    Codec configuration box : hvcC
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : mp4a-40-2
    Duration : 8 s 976 ms
    Bit rate mode : Constant
    Bit rate : 192 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 SPF)
    Compression mode : Lossy
    Stream size : 210 KiB (0%)
    Title : SoundHandle
    Language : English
    Mar 2008
    The file shows
    Does it play back properly on the phone? Perhaps you can upload a smal sample
    Feb 2022
    New York
    The file shows
    It looked fine on the phone, but it's a small screen.
    Mar 2008
    My PC is too slow to properly play this file, so I played it on my TV via the DLNA network.
    The audio follows the video properly, but may be a fraction, I don't think it's as much as a 1/3 of a second, early
    Is this what you see?
    Is this re-encoded version in sync?
    Feb 2022
    New York
    You are right it's about -150ms. This is one of the original files.
    Mar 2008
    Yet in the re-encoded version above, the sync is better (or so it appears to me).
    I did not adjust the sync at all, just re-encoded the video and copied over the existing audio
    If you want to experiment with an audio offset, get FFmpeg and test with this command. This example delays audio for 200ms
    ffmpeg -i source.mp4 -itsoffset 0.200 -i source.mp4 -map 0:v -map 1:a -c:v copy -c:a newfile.mp4
    Feb 2022
    New York
    Thank you so much for your help. I figured out that the audio delay was caused by my Bluetooth-connected speakers. Switched to the hardwired setup - all good. Sorry for your time, but I still learned a lot!
    Mar 2008
    yes this doesn't surprise me, especially since these files are straight out of the phone and should be good.
    Even in my case, playing over the network, it was so close it was questionable if it was just a performance problem.
    2nd clue is the video reencode/audio passthrough to a less demanding file, no problems there
