Hi,
I am looking for a possibility to add certain information (here "writing library" as well as "Encoding settings") into the hevc Bitstream after encoding so that mediainfo is able to present it an appropriate way.
Background:
I only found very sparse information regarding this concern on the internet, but almost everything in the opposite direction: how to remove thus information.
(E.g., even it is closed bc of violation of rules by the OP:
https://forum.videohelp.com/threads/394432-Metadata-Editing-%28Protect-or-modify-information%29)
I am not interested in this. My concern is how to add such information. For example I want to make my settings public etc.
What I did but with little or no success was to open the file in a Hexeditor and tried to add some lines. But of course, it failed.
I certainly could just re-encode the whole thing but I hope that there might be a more time and energy saving way.
As I noticed in the abovementioned (closed) thread, please apologize if my concern does not make any sense in your opinion.
I want to understand and learn how to find a (more or less) satisfying solution. I should further mention that I do not have well programming skills, unfortunately. However, I would be grateful if someone can assist me
EDIT:
currently, my encode looks like this:
Video ID : 1
Format: HEVC
Format/Info: High EfficiencyVideo Coding Format
profile : Main@L4@Main
Codec ID : hev1
Assuming that I want to add my encoder settings etc, the following should be result some like (without re-encoding);
Video ID : 1
Format: HEVC
Codec ID : hev1
Writing library : x265 2.6:[Linux][GCC 7.2.0][64 bit] 8bit+10bit+12bit
Results 1 to 1 of 1
Why is VLC adding "Exile Evolution" album cover to any media I try to play
By rrats in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2021, 04:10 -
"can't process HEVC source, aborted" error
By zapaptoroto in forum Newbie / General discussionsReplies: 3Last Post: 28th Sep 2018, 13:19 -
HEVC Encoder and settings
By Cyano in forum Video ConversionReplies: 3Last Post: 8th Feb 2018, 06:55 -
"General" encoding methods and settings
By Vol4Ever in forum Video ConversionReplies: 11Last Post: 12th Jan 2018, 18:41 -
Request MKVToolNix GUI popup "adding or appending files" dialog explanation
By JBC in forum EditingReplies: 1Last Post: 6th Jan 2018, 14:43
