Hi,
I am backing up my 8mm Tapes to my PC. I have a Samsung VP-L700 (old) Camcorder and my PC running windows 7.
I use Roxio - Media Import - for importing the tapes.
Using an S- Video cable between the PC and Camcorder - it transfers the Video but no Audio.
When I google why and check the manual - I am advised that - Audio needs to be transferred separately - and the only option I have is from the A/V Out port on the Camcorder. And on the PC I have a PCI M779 card.
What are my options / What t cable do I need to buy?
Pictures attached for reference - of PCI card and of AV Out Jack plug on Camera. Thank you.
s-vid ports and cables only carry video. you need to use the red and white rca jacks for audio. that card has what looks like a stereo mic type jack input for audio. i'd try a cable that takes the red and white rca plugs and converts to male stereo mic jack.
According to the user manual, that camcorder uses a combined audio + video proprietory cable. It should have been in the box so I guess you have mislaid it.
The following claims to work for your camcorder.
https://www.ebay.co.uk/itm/223712458166?hash=item34164d35b6:g:IRwAAOSwWAhcLOzF
However, since the connector also carries video there may be a conflict between the s-video and the composite carried by this cable.
But before you buy this I would check from another RCA cablle that the connector does indeed fit your capture card.
Audio will only be mono from the camcorder.
How to include audio in an overlay ffmpeg command?
By giladsof in forum Video ConversionReplies: 2Last Post: 27th Apr 2021, 10:36 -
Original file in mp4 format from Reflecta 8mm Super 8mm scanner
By Sajmon in forum RestorationReplies: 0Last Post: 27th Feb 2021, 12:56 -
Do Sony Digital 8 Camcorders Play Back 8mm as Well as 8mm Equipment?
By audioresearch in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 18th Jun 2020, 02:12 -
TRV120 D8 cam won't play most old 8mm tapes, any recommended 8mm camcorders
By analog2digital in forum Capturing and VCRReplies: 1Last Post: 22nd Feb 2020, 12:44 -
How to extract audio track of .avi file to include it in a .mkv file?
By nickiman in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jul 2019, 07:15
