I want to be able to copy subtitles without changing spelling, etc., with Subtitle Edit? When I Start OCR it does weird things such as making the letter w to vv? Before running that it recognizes letters and numbers, but changes them after.
How do I ensure it copies the subs without attempting to change anything?
All you can do is correct the errors,subtitle will remember the corrections and it will get easier after awhile.
If you have time on your hands and want to experiment you can try an old, NO LONGER DEVELOPED piece of software called DVDSubEdit. It’s rated 9.8, but that was back then. It might not even install on today’s operating systems. I remember using it. I remember I had a VOB subtitle that SubtitleEdit could not convert no matter what. DVDSubEdit had no problem with it. I have run into SubtitleEdit turning a w into vv also and it doesn’t always remember changes. DVDSubEdit has a few slider controls that loosens/tightens the OCR sensitivity.
Another piece of NO LONGER DEVELOPED software that might help is PgcDemux. I used to use it but for the life of me I cannot remember what exactly I did or what input is necessary.
Sorry I’m so iffy on these applications but it has been a while. I no longer have them installed. Check them on out under Subtitle Editors, Converters (70) and see if they might be of some use to you.
Don’t forget there is always SubRip. I’ve never had any luck with it plus it was time consuming and not very accurate. -
Use this OCR engine to convert your subtitle images to text
https://github.com/tesseract-ocr/tesseract -
Great info - Subtitle Edit Help - Add subtitles to video
By yepyep in forum SubtitleReplies: 0Last Post: 15th Apr 2021, 09:05 -
Problem when batch converting subtitles using Subtitle Edit
By IdontKnow in forum SubtitleReplies: 3Last Post: 21st Mar 2021, 10:24 -
how do i sync of subtitles with the movie by using subtitle edit
By jraju in forum SubtitleReplies: 3Last Post: 19th Oct 2019, 23:50 -
Big problem :-( Translating subtitles on Subtitle Edit into Hebrew
By Asubtitler in forum SubtitleReplies: 4Last Post: 30th Dec 2018, 08:42 -
Can I visualize overlapped subtitles on Subtitle Edit video player?
By brgsbel in forum SubtitleReplies: 1Last Post: 2nd Apr 2018, 16:05
