Hi there
Editing a video using the above software is easy with minimum knowledge required. The same doesn't seem to be the case when it comes to audio! I've tried going through various how-to's to discover something very simple, but I am none the wiser?
All I want to do is mute about one second of unwanted noise in the middle of an MKV file?????
HELP
Extract the audiostream with mkvcleaver, modify it with an audioeditor (ge audacity) and remux it then with mkvtoolnix
I have tmpg authoring works which is limited when compared to mastering works, but this is how I would go about it:
I would duplicate the clip 3 times and edit/cut/split each clip. So clip 1 would be the start of your file to right before the noise you want to mute occurs. Clip 2 would be the section of noise. Clip 3 would be after the noise to the end of your file.
Select clip 2 and select the filters tab (may also be listed as “audio filters”). Find volume adjustment in the list and take it to 0%. This should mute clip 2
When choosing your output file make sure “save as one file” is selected
I also found this basic guide to help with mastering works:
https://researchguides.case.edu/editav/video
ProWos reply is much easier, but if you have to use tmpg mastering you can try what I listedLast edited by mazinz; 6th Feb 2022 at 14:18.
tmpgenc mastering works 5 and mov files
By devdev in forum EditingReplies: 2Last Post: 6th Aug 2020, 11:15 -
TMPGenc Video Mastering Works v6 - need a smaller output file
By vhwul62 in forum EditingReplies: 5Last Post: 13th Jun 2020, 04:07 -
DVDFab, TMPGEnc Video Mastering Works 7, or Handbrake to X264/X265
By magnu in forum Video ConversionReplies: 3Last Post: 27th Jun 2019, 11:42 -
Video Edit - Cutting a section of video from a larger video file
By bpatters69 in forum EditingReplies: 14Last Post: 10th Nov 2017, 11:33 -
TMPGenc Video Mastering Works 6 Deinterlacing settings
By magnu in forum RestorationReplies: 25Last Post: 8th Aug 2017, 12:43
