  1. Hello. I have started recording some shows using tvheadend (ott, sat, iptv). The .ts files play using vlc but when I try to remux them using mkvmerge/toolnix, only the audio track is detected and it outputs a .mka file. Does anyone know what caused this and if it can be "fixed"?
    Cheers,
    Chris
    EDIT: I should add that ffmpeg is able to convert the files using the command
    HTML Code:
    ffmpeg -i <file> output.mkv
    I am trying to figure out why mkvmerge has issues and how I can fix them because I'd like to "import" the files into my sonarr workflow where one of the post processes is stripping unwanted tracks from files using mkvmerge.
  2. Are you using the most recent version?
    You can post on the issue tracker, with a ts sample
    https://gitlab.com/mbunkus/mkvtoolnix/-/issues
  3. I do not know which version I am using in the script.
    In windows I am using the latest version of mkvtoolnix gui.
    ffprobe give the following... Lots of errors.... But ffmpeg is still able to convert while mkvmerge cant.
    HTML Code:
    C:\Users\Chris>ffprobe C:\Users\Chris\Downloads\test.ts
    ffprobe version 2021-11-22-git-203b0e3561-full_build-www.gyan.dev Copyright (c) 2007-2021 the FFmpeg developers
      built with gcc 11.2.0 (Rev2, Built by MSYS2 project)
      configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libdav1d --enable-libdavs2 --enable-libuavs3d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint
      libavutil      57.  9.100 / 57.  9.100
      libavcodec     59. 13.100 / 59. 13.100
      libavformat    59.  9.101 / 59.  9.101
      libavdevice    59.  0.101 / 59.  0.101
      libavfilter     8. 17.100 /  8. 17.100
      libswscale      6.  1.100 /  6.  1.100
      libswresample   4.  0.100 /  4.  0.100
      libpostproc    56.  0.100 / 56.  0.100
    [h264 @ 000001b1bc223d00] non-existing PPS 0 referenced
        Last message repeated 1 times
    [h264 @ 000001b1bc223d00] decode_slice_header error
    [h264 @ 000001b1bc223d00] no frame!
    [mpegts @ 000001b1bc21e2c0] decoding for stream 0 failed
    [mpegts @ 000001b1bc21e2c0] Could not find codec parameters for stream 0 (Video: h264 ([27][0][0][0] / 0x001B), none): unspecified size
    Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options
    Input #0, mpegts, from 'C:\Users\Chris\Downloads\test.ts':
      Duration: 01:03:59.94, start: 32.183489, bitrate: 5769 kb/s
      Program 1
        Metadata:
          service_name    : Service01
          service_provider: FFmpeg
      Stream #0:0[0x100]: Video: h264 ([27][0][0][0] / 0x001B), none, 25 fps, 25 tbr, 90k tbn
      Stream #0:1[0x101]: Audio: aac (LC) ([15][0][0][0] / 0x000F), 44100 Hz, stereo, fltp, 255 kb/s
    Apr 2007
    Australia
    As you're using vlc perhaps create a new file and then see what you get with mkvmerge/MKVToolnix.
    https://www.howtogeek.com/434475/how-to-convert-a-video-or-audio-file-using-vlc/
    Cheers
    p.s. I notice in the howtogeek example, the user's name is Chris.
    Apr 2007
    Australia
    Hi.
    Find out what streams mkvmerge.exe can find.
    mkvmerge -i "input.ts"
    From here: https://mkvtoolnix.download/doc/mkvmerge.html
    If tracks are known to be present but not found then the percentage to probe can be changed with this option. The minimum of 10 MB is built-in and cannot be changed.
    Perhaps bump up the probe range percentage from the default.
    mkvmerge.exe --output "output.mkv" "input.ts" --probe-range-percentage 2.00
    Cheers
  6. Thanks for the reply. I tried that but even at 100.0 it didn't find the track.
