Some newer divx movies state they need SMR codec. I have downloaded several smr codecs but none seem to work. Movie is blank and no sound.
Does anyone know anything about SMR?
I'm with you on this one Greg ...
I got the same problem (no video / no sound)
and i've tried the SMRcodec install 4 times now
Did you ever get an answer?
thanks
Tony -
The files could be fakes. I have found a lot of files with (smr) in the name but when I play them I get nothing. If ya didn't get it from an smr source then you are taking your chances on what you are downloading.
Which codec?
By Andyncu in forum Video Streaming DownloadingReplies: 5Last Post: 13th Feb 2011, 08:11 -
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Which codec should I use?
By TSWatson in forum ProgrammingReplies: 9Last Post: 23rd Apr 2010, 07:25 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41
