Hello, I've managed to track down a good used Panasonic DMR-EH57-S DVD locally for sale that i wish to use as a passthrough to stabilize my signal for signal capture, would this unit do the job? I am well aware of the typical models often mentioned but they are nowhere to be find so that's not an option.
Yup, it works great, I use that model for this purpose usually via the HDMI output. Just be vary of the same caveats as the other PAL panasonic dvd-recorders - very bright spots can get blown out if you don't manually lower the video signal going into it with e.g a passive volume control, and the power supply capacitors can go bad over time making the unit not turn on (Had to replace one on mine before it would turn on).
Panasonic DVD recorder passthrough settings (DMR-ES10, DMR-ES15, DMR-ES25)
By Brad in forum Capturing and VCRReplies: 466Last Post: 22nd Aug 2025, 09:30 -
Panasonic DMR-ES15 PAL - how to setup for TBC passthrough
By spotty in forum Capturing and VCRReplies: 9Last Post: 30th May 2023, 06:06 -
Panasonic dmr-e75v - how read my dvd
By anika in forum DVD & Blu-ray RecordersReplies: 1Last Post: 2nd Feb 2022, 20:36 -
DMR-ES20 as a passthrough
By AmigaFanBoy in forum Capturing and VCRReplies: 5Last Post: 13th Nov 2019, 16:23 -
Is it possible direct recording on dvd r with Panasonic dmr ex768
By nusratjaveid in forum DVD & Blu-ray RecordersReplies: 6Last Post: 20th Aug 2017, 13:40
