i am using the program handrake to compress my video files. assume that i add the file xyz.mp4 to the program
the video encoder that i am using is h.264 (x264). if i choose that video encoder then the output file is becoming Xyz.m4v. i am changing it to xyz.mp4 and then i am doing the compression. the encoded videos are working fine
i just want to confirm that i am allowed to put .mp4 instead of .m4v
mp4 is more widely accepted as a playback format on very many devices so you are not wrong to choose mp4.
You can set Handbrake to default to mp4 if you look in the preferences menu.
Use the option to 'always use mp4'
[Attachment 63174 - Click to enlarge] -
.m4v IS .mp4.
I think it was Apple who originated the idea of using .m4v, .m4a, etc. to further differentiate what's in an .mp4 stream. (.m4v = MP4 video, .m4a, an audio-only MP4 stream, and so forth (I know they have some other variations, such as for audiobooks, but I don't remember them off the top of my head.))
But, yeah, if you're working with a device or stand-alone player, you may need to rename the extension to .mp4 for the player to properly recognize it.If cameras add ten pounds, why would people want to eat them? -
M4V was already defined (an mpeg 4 elementary video stream) before Apple started using it for MP4 videos. They just changed the extension for MP4 when they added support for AC3 audio (15 years after all the other containers). Older Apple devices (without AC3 support) wouldn't try to play the files. That way they could tell all their users they needed a new hardware to play the new files.
Ah, okay. I just never saw it in 'widespread use' until after Apple made their changes.
Rewrap MTS to MP4 w/o re-encoding. Why is MP4 smaller? GUI batch tool?
By Razz in forum Video ConversionReplies: 7Last Post: 13th Mar 2021, 17:24 -
Can’t Save Final VurtualDub2 File as an MP4 (only AVI)
By Avagadro1 in forum EditingReplies: 24Last Post: 26th Aug 2020, 15:34 -
VirtualDub -- “SAVE”, “SAVE AS”, “EXPORTING”, re-encoding
By Avagadro1 in forum EditingReplies: 2Last Post: 13th Aug 2020, 12:44 -
Split mp4 file into specified size (part1.mp4, part2.mp4 etc.)
By TubeBar in forum EditingReplies: 7Last Post: 1st Feb 2019, 23:41 -
how can i join two videos a1.mp4 + a2.mp4 = a12.mp4
By sommers in forum Newbie / General discussionsReplies: 14Last Post: 8th Jun 2017, 19:01
