in this tutorial https://youtu.be/DiDmUg8aRnE?t=193 about handbrake the guy is talking about the conversion speed and he said that the speed that you select affects the quality. i don't get that. the conversion speed is how fast the program does the conversion. how does that affect the quality of the video?
for example there is another converter program called movavi video converter premium. in that program the conversion speed is fast and you can just run the program as a background task to use less cpu power and i don't think that affects the quality of the video
how come the conversion speed doesn't affect the quality if movavi video converter premium is used but it affects the quality if handbrake is used?
That's because you interpreting the claim literally. What is meant here, is that technically speaking faster presets/settings will give you lower quality (means less like the original) output vs slower presets. It's not always easy to spot for naked eye though. In case of overkill bitrate settings the difference is virtually non-existent.
The slower presets use more, and more accurate but slower, methods to compress the video.
Never use ultrafast for anything other than a quick dirty test. Or for video capture at crf=0 (lossless).
Here are some example videos, both encoded at CRF=17 (as in the youtube video). One at ultrafast the other at slower. First, notice that ultrafast is much larger. It must be better quality right? Now watch them in a darkened room... -
If you want to experiment for yourself here's the source (lossless x264, 8 bit YUV 4:2:0) from which those two videos were encoded.
Slow conversion speed in MKVmerge
By carlmart in forum Video ConversionReplies: 25Last Post: 31st Jan 2021, 09:45 -
Does setting the ffmpeg -preset affect quality? Does Handbrake preset?
By LaserBones in forum Newbie / General discussionsReplies: 7Last Post: 15th Jul 2020, 13:01 -
video card to help conversion speed in DVDFab
By Catbird78 in forum Newbie / General discussionsReplies: 2Last Post: 27th May 2020, 07:22 -
MAGIX HEVC/AAC MP4 settings, preset quality, what does it affect?
By SF01 in forum EditingReplies: 5Last Post: 14th Mar 2020, 13:07 -
VirtualDub Conversion unintentionally also changes video speed
By hwvd7 in forum Video ConversionReplies: 11Last Post: 4th Oct 2017, 06:42
