  1. Dears,
    i am unable to correctly process subtitles from BD during encoding using HandBrake Version 1.3.3 (2020061300) (for macOS).
    inside the program, under Subtitle tab i selected desired subtitles from track column then optionally uncheck or check the options "Forced Only" "Default" (Option "Burned in" i always unchecked).
    After the encode i have usually two results:
    - Subtitles are visible under menu option but wont display in the movie while playing
    - Subtitles are visible under menu option but they display during the movie 20% higher on the screen (position)
    Note: Yes, i have automatically cropped during the encoding the upper and bottom black bars
    Any suggestion how to rip the BD and to have the subtitles displayed correctly and always visible?
    Thank you
    Kind Regards,
    VLP
    Feb 2006
    Originally Posted by vlp_007 View Post
    Dears,
    Thank you
    Kind Regards,
    VLP
    try check burn in then uncheck default - https://www.reddit.com/r/handbrake/comments/mpq9uc/cant_burn_in_subtitles/
    also see this thread - https://www.reddit.com/r/handbrake/comments/mv4l7o/subtitlesagain/
  3. It sounds, that "Burned in" means to have subtitles directly burned into the movie screen. I dont want this. I want to decide if i will enable them or not during playing the movie.
    Is there any tool that will extract the subs from BD and then process them, add them later via MKVtoolnix and all will be ok again?
