i capture using dazzle mpeg2dvd settings but when put in tmpeg
keep getting message cannot encode files will encode mpeg1 fine
can someone help
thanks
You give VERY little info about what you wish to acomplish, but i assume you want to encode the file into MPEG-2(?) since MPEG-1 works fine. Remebber that the MPEG-2 engine have a 30day limit if you don't have the full Plus version...
If your problem is that you can't read the files you might need a VFAPI plugin....
If i'm way off, please post more presice info...
TMPEnc Authoring Works 4 Problem with input AC3 Audio (5.1 channels)!!!
By JackyWang in forum Authoring (DVD)Replies: 10Last Post: 22nd Jun 2011, 10:46 -
Problem with TMPEnc DVD Author 3
By ebadillab in forum Authoring (DVD)Replies: 11Last Post: 28th Jul 2009, 06:23 -
Progressive AVI encoding to DVD in TMPEnc - interlaced?
By Xoanon in forum Authoring (DVD)Replies: 16Last Post: 9th Jan 2009, 11:01 -
error in tmpenc
By php111 in forum Newbie / General discussionsReplies: 4Last Post: 4th Aug 2007, 07:56 -
Problem with TMPEnc
By Technophobe in forum Video ConversionReplies: 3Last Post: 28th Jul 2007, 16:44
