Page 3 of 3
FirstFirst 1 2 3
Results 61 to 65 of 65
    Sep 2024
    St. Louis, MO USA
    Nah, still jitters like crazy. I noticed however, that your overall bitrate is variable, whereas mine is constant. I wonder if that has to do with anything.
    Here's yours:
    General
    Complete name : C:\Users\chris\Desktop\ch3b.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom (isom/iso2/avc1/mp41)
    File size : 6.96 MiB
    Duration : 1 min 23 s
    Overall bit rate : 699 kb/s
    Frame rate : 23.976 FPS
    Writing application : Lavf61.7.100
    Video
    Format : AVC
    Format profile : High@L3
    Format settings : CABAC / 4 Ref Frames
    Format settings, CABAC : Yes
    Format settings, Reference frames : 4 frames
    Codec ID : avc1
    Bit rate : 443 kb/s
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 3:2
    Frame rate mode : Constant
    Frame rate : 23.976 (24000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.053
    Stream size : 4.41 MiB (63%)
    Writing library : x264 core 157 r2935M 545de2f
    Encoding settings : cabac=1 / ref=2 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=hex / subme=4 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-1 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=20 / rc=crf / mbtree=1 / crf=22.1 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Color range : Limited
    Matrix coefficients : BT.470 System B/G
    Codec configuration box : avcC
    Audio
    Format : AAC LC
    Format/Info : Advanced Audio Codec Low Complexity
    Codec ID : mp4a-40-2
    Source duration : 1 min 23 s
    Source_Duration_LastFrame : -19 ms
    Bit rate mode : Variable
    Bit rate : 251 kb/s
    Maximum bit rate : 256 kb/s
    Channel(s) : 2 channels
    Channel layout : L R
    Sampling rate : 48.0 kHz
    Frame rate : 46.875 FPS (1024 SPF)
    Compression mode : Lossy
    Stream size : 2.49 MiB (36%)
    Source stream size : 2.50 MiB (36%)
    Default : Yes
    Alternate group : 1
    And here's mine:
    General
    Unique ID : 48748706063284554097892053577302587779 (0x24ACA8C64B833635A44F591EFAE0B983)
    Complete name : C:\Users\chris\Desktop\Video Related\Miscellaneous\Inverse Telecine\Processed_Video.mkv
    Format : Matroska
    Format version : Version 4
    File size : 1.81 GiB
    Duration : 45 min 15 s
    Overall bit rate : 5 728 kb/s
    Writing application : Lavf61.5.101
    Writing library : Lavf61.5.101
    ErrorDetectionType : Per level 1
    Video
    Format : AVC
    Format profile : High@L3.1
    Format settings : CABAC / 8 Ref Frames
    Format settings, Reference frames : 8 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 45 min 14 s
    Bit rate : 5 422 kb/s
    Width : 720 pixels
    Height : 480 pixels
    Color space : YUV
    Bit depth : 8 bits
    Scan type : Interlaced
    Original scan type : Progressive
    Scan type, store method : Interleaved fields
    Scan order : Top Field First
    Bits/(Pixel*Frame) : 0.654
    Stream size : 1.71 GiB (95%)
    Writing library : x264 core 164
    Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=12.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Default : No
    Forced : No
    Color primaries : BT.601 NTSC
    Transfer characteristics : BT.601
    Matrix coefficients : BT.601
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Commercial name : Dolby Digital
    Codec ID : A_AC3
    Bit rate mode : Constant
    Bit rate : 192 kb/s
    Frame rate : 31.250 FPS (1536 SPF)
    Bit depth : 32 bits
    Stream size : 62.1 MiB (3%)
    Writing library : Lavc61.13.100 ac3
    Service kind : Complete Main
    Default : No
    Forced : No
    Dialog Normalization : -31 dB
    dialnorm_Average : -31 dB
    dialnorm_Minimum : -31 dB
    dialnorm_Maximum : -31 dB
    May 2005
    PAL User
    Chris, I'd try cracking your DVD with DVDShrink to get the raw VOB/s to look at (it has been able to decrypt most DVDs).
    For DVDShrink:
    For ripping Main Movie only:
    -Choose Re-Author.
    -On the DVD Browser tab, drag the main title to the left window
    -On the Compression tab:
    -Choose no compression
    -Untick all unwanted Audio and subpicture items
    -Click Backup!
    If you want, Edit>Preferences> Output Files tab and untick 1gb chunks. You’ll then get 1 big VOB.
    Sep 2024
    St. Louis, MO USA
    I did that with WinX DVD Copy Pro, Alwyn. One of the many different things I've tried.
    When cloning the DVD to an ISO or Video_TS Folder, the actual videos worked beautifully when QTGMC de-interlaced. The downfall is, I can't get the 1GB VOB files to merge seamlessly. I'd tried with an FFmpeg script and other various apps, but there's always a glitch, stutter, frame drop, audio drop, etc., right at the end of one VOB continuing onto the next. So I had to scrap that one a long time ago as well.
    May 2005
    PAL User
    Just suggesting different options. The workflows you used didn't work. Others can be tried. For example, DVDShrink will give you one big VOB (as per my post above), with, from what I have seen, no issues at the joins. And AVIDemux will join up a VOB set and recontainerise them into one MPEG 2.
    Then IVTC the single VOB.
    Sep 2024
    St. Louis, MO USA
    I'll have to try that when I get a chance.
    Thank You for the suggestion, Alwyn.
