Hi
I'm having problems with tmpgenc 2.5 NOT REGISTERED. I am following (Sefys classical newbie start DVD Ripping guide) when I encode a whole movie it seems to work fine but when I use vcd easy 1.0.9 I have problems when I press add files button and it won't find the mpeg1 file so I look to see if the file is in there and it is but it looks like a windows file not a video camera file. With this file that I have probelms with I right click on it and go open with windows media player and the movie plays.
I have done an hour of one movie and minute of another and they both worked fine when finding the file when I press the add files button in vcd easy.
Why is this happening?
I Believe you just forgot to add the extention to the file name, and VCDEasy looks for .mpg or .mpeg files, and your file has no .mpg or .mpeg so it can't find it, just rename the file and add the .mpg to it.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Problems with TMPGEnc...
By SolsBBQ in forum Video ConversionReplies: 5Last Post: 3rd Jan 2009, 06:00 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 18:37 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
By maccool111 in forum ComputerReplies: 3Last Post: 23rd Jul 2007, 16:47
