Been using these two since 2008 on both my Intel Q6600 without issues.
MPC-HC.1.9.19.x64.exe
MPC-BE.1.6.1.6845.x64.exe
Recently built a new PC with Alder Lake i5-12600K with build in IGPU Intel HD 770, and now both players would play the video for 1 or 2 secs and gone black/blank but sounds continues.
I tried removing MpcVideoRenderer as well as madVR, still no go, both players are always using H/W IGPU.
What can I try, and how does one disable H/W GPU acceleration in both MPC-BC and MPC-HC?
Thanks.
Download the k-lite pack https://codecguide.com/download_kl.htm
seems there is a bug or broken with iGPU of 12th / Alder Lake, I've the 12600K with same Intel HD 770 , EVR CP & HW LAV decode works here but no overlays informations are displayed , no overlay for Play/Pause or Subtitles.
VLC is ok.
MPC HC even cannot play somes 4k HEVC 10bits two = weird video.
bypassing Intel HD 770 with an old pcie GeForce 210 , overlays Play/Pause & Subtitles works immediatly and some 4k hev 10bits play fine too.
edited : MpcVideoRenderer from https://github.com/Aleksoid1978/VideoRenderer/releases fix my problem of "Play/Pause" overlay & weird video on some 4k hevc 10bits. HW acceleration D3D11 is OK.Last edited by sonic9; 11th Mar 2022 at 17:00. Reason: updated , fixed with MpcVideoRenderer
Comparing MPC-HC vs MPC-BE
By vhwul62 in forum Software PlayingReplies: 10Last Post: 9th Jan 2021, 08:13 -
sync offset and jitter values in mpc-hc and mpc-be
By Milardo in forum Capturing and VCRReplies: 0Last Post: 16th Nov 2020, 19:29 -
MPC-BE controls & etc as overlay, not docked at the bottom of the video?
By hsregsfsdfsasdf in forum Software PlayingReplies: 0Last Post: 8th Nov 2019, 21:39 -
Feature request for mpc-hc & mpc-be
By babai89 in forum Software PlayingReplies: 5Last Post: 9th Aug 2017, 19:37 -
Media Player Classic / MPC-BE / MPC-HC : differences between them
By devilcoelhodog in forum Software PlayingReplies: 19Last Post: 25th Jun 2017, 18:54
