Dobrý deň chcem sa opýtať mám problem mam vcr a pri prehravaní je akokeby posunuty obraz o kúsok dole, mam čierny pás u vrchu televízie neviete poradiť čim to môže byťbuť mechanikou , elektronikou alebo bubnami inač funguje prehravanie aj pretačanie
You really must write in English to expect replies.
And VR (as far as this forum is concerned) means Virtual Reality and not Video Recorder.
As for your problem (Google translated) you need to elaborate as to whether this issue is on a tv (vertical hold) or elsewhere -
Television is running smoothly strip on the screen is horizontal. The black band is from the top of the tv when the tape is playng. Tv broadcast is ok. In what may be a mistake?
Troublshooting hardware over a public forum is only possible when the person asking for help is skilled enough to do basic hardware repair/troublshooting, have all the required tools and only looking for directions, There is no magic here. Otherwise just look for a skilled technician in your area to get the job done.
Panasonic writer
By unclebob in forum ComputerReplies: 5Last Post: 19th Dec 2018, 13:34 -
Panasonic DMR es-18
By Joe S in forum Newbie / General discussionsReplies: 2Last Post: 14th Sep 2017, 16:34 -
Software to trim AVCHD MP4 files from a Panasonic Panasonic DMC-TZ70
By Vladimir81 in forum EditingReplies: 2Last Post: 29th Aug 2017, 05:15 -
anyone used this Panasonic HC-V770K ?
By geoffcox in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 6th Jun 2017, 10:16 -
Panasonic DVD
By Margaret in forum DVD & Blu-ray PlayersReplies: 5Last Post: 22nd Apr 2017, 23:00
