It runs the video, but the colors are weird. I've already tweaked everything but it seems that it only works with normal colors on pure ntsc tapes. And yes, i have a transcoder for pal-m tapes.
In case you did not know.....
PAL-M is neither PAL nor NTSC. It has mostly NTSC format but with PAL timing/sub carrier @ appr. 3.58 mhz. It is unique to Brazil and, I guess, they used modified vcrs to record the analog signal. A friend of mine sent me a recording some years ago - played in B&W - and I needed to send it away for a conversion to finally see the colour.
Seems that your vcr will only output pure NTSC* so a transcoder will do nothing. According to Wiki there does exist some vcrs that will output/convert the signal
https://en.wikipedia.org/wiki/PAL-M
Or you would have to use a true multi-system vcr
* That will also be known as NTSC 4.43. There is a playback format known as NTSC 3.58 but I do not know if this is the same as those vcrs mentioned in the Wiki or what other vcrs support that or even if that is compatable with PAL-M -
I hope you don't mean by "tweaked" alter factory adjustement of potetiometers inside the VCR, because that would require hell of an effort to dial them back in to factory values using the oscilloscope and factory alignement tapes. and why would you use an expensive D-VHS deck for this purpose anyway?
The signal on tape is different to NTSC, so you need an actual PAL-M capable VCR to play it back with color, which will usually be either one of the fancy "worldwide VHS" multi-system VCRs, or one that was released in brazil.
Help in watching VHS-C secam tapes on PAL equp.
By Out_In_The_Cold in forum Newbie / General discussionsReplies: 2Last Post: 25th Aug 2021, 13:21 -
Dual VHS/VHS-C VCRs to play VHS-C tapes wthout adapter
By Bsmarado in forum RestorationReplies: 7Last Post: 18th Mar 2021, 06:04 -
Any difference between NTSC and PAL blank (S)VHS tapes ?
By JoseD in forum MediaReplies: 2Last Post: 24th Sep 2019, 20:03 -
How can I watch my PAL VHS Tapes on NTSC TV?
By artemis in forum Video ConversionReplies: 2Last Post: 30th Jul 2018, 04:50 -
Is it true all PAL VCRs can play NTSC, PAL, SECAM tapes?
By digicube in forum Capturing and VCRReplies: 26Last Post: 16th Sep 2017, 11:20
