hi, I have an ac3, 1:49:16.228 long.
I would like to trim it and save a sample that start at 0:03:40 and ends at 0:05:40.
I first give the ac3 the following command:
%_.ac3 -220000ms
the new edited ac3 starts correctly at 0:03:40.
but now, what command to tell eac3to to cut this edited file from 0:02:00 to the end?
edit: ok I did it by using
%_.ac3 -edit=0:02:00.000,-6336228ms
where 6336228ms is the difference between 1:49:16.228 and 0:03:40
is it possible to save a part in the middle of an ac3 with more elegant commands,
without converting to ms and subtracting or anyway in a single command and job?
Results 1 to 1 of 1
BeSplit AKA eac3to PCM-to-AC3 questions
By ArianK in forum AudioReplies: 0Last Post: 9th Jun 2021, 00:45 -
eac3to volume difference
By killerteengohan in forum RestorationReplies: 0Last Post: 2nd Apr 2021, 06:06 -
Eac3to
By gartzo in forum AudioReplies: 3Last Post: 17th May 2018, 09:18 -
Popcorn and eac3to
By marinewonder in forum Video ConversionReplies: 2Last Post: 26th Dec 2017, 06:04 -
EAC3To Incorrect Slowdown? EAC3To Broke?
By TheLastOfThem in forum AudioReplies: 44Last Post: 13th Jul 2017, 21:42
