  1. Hey all I have been trying to get the settings correct with this cli:
    HTML Code:
    ffmpeg -i "V:\weather animations\light snow.mov"
           -framerate 15
           -plays 0
           -s 480x480
           -vf setpts=PTS-STARTPTS
           -f apng "V:\weather animations\light snow.apng"
    Though the above command line does produce an animated apng file Its almost half the size as the original (its 750x750).
    The original size of the mov:
    When I use an online converter like ezgif it has the size of 8mb for the same thing above running the local ffmpeg command line.
    So what setting am I forgetting?
  2. Can you clarify what are you asking about the "output size" . What did you expect ?
    What format is the original mov ? What codec ? What framerate? You can use mediainfo or ffprobe
    GIF uses a limited pallette, 256 colors, so it's not comparable in terms of quality or filesize
