I've spent the past year slowly plugging away at capturing some NTSC VHS tapes. I had to create notes to keep things straight, so I thought I'd share them in case they help others. I'm a newbie. Not an expert. These are not comprehensive. Take them for what they are.
Here is what I used in my setup: JVC SVHS HR-S2913U > DMR-ES15 > Pinnacle 710 USB > Windows 10 > Virtual Dub 1.9.11 .
NTSC VHS newbie overall summary: Capturing
NTSC VHS newbie overall summary: Processing & Conversion
NTSC VHS newbie summary #3: Pinnacle 710 USB Capture Device
I tested 3 capture devices and found that the Pinnacle 710 USB was the best for both audio & video on Windows 10 (when using virtualDub 1.9), but that wasn't surprising based on what's in this forum.
Here is my comparison of (a) Honestech VHS to DVD 5.0 (b) Roxio Easy VHS to DVD 3 PLUS and (c) Pinnacle 710 USB device
https://forum.videohelp.com/threads/403619-Sharing-snapshots-from-4-different-capture-methods
I learned of the Pinnacle 710 USB device because it is recommended for windows 10 by lordsmurf:
http://www.digitalfaq.com/forum/marketplace/8253-sale-ati-600-a.html
"For windows 10: Pinnacle 510 / 710 USB, NTSC, similar to ATI AIW USB, WinXP/V/7/8/10 all work well"
Setup Steps:
(Credit to lordsmurf)
- Drivers: Download & install drivers, reboot is required. From: http://www.digitalfaq.com/forum/video-capture/10136-virtualdub-capturing.html#post64929
- CrossbarThing: Download, install and start "Crossbar Thing", set to s-video crossbar. Close. http://www.digitalfaq.com/forum/video-capture/9379-how-enable-video.html#post58837
- Then open VirtualDub, capture mode. (NOT VirtualDub2) http://www.digitalfaq.com/forum/video-conversion/1727-virtualdub-filters-pre.html
- Preview mode, not overlay.
- Set to s-video if needed (if not already showing s-video), should look perfect.
lordsmurf: "Notes:
- Do not use VirtualDub2.
- Crossbar Thing is only need for post-XP (Vista/7/8/10)
- For some XP systems, Overlay may work fine on the 710."
From http://www.digitalfaq.com/forum/video-capture/11051-pinnacle-710usb-windows.html#post71898
Results 1 to 1 of 1
Last edited by brockway; 9th Feb 2022 at 19:00. Reason: added links to overall summaries
NTSC VHS newbie summary #2: TBC Budget option: Panasonic DMR-ES10 ES15
By brockway in forum Capturing and VCRReplies: 0Last Post: 14th Jan 2022, 11:39 -
NTSC VHS newbie summary #1: VCRs & settings
By brockway in forum Capturing and VCRReplies: 3Last Post: 14th Jan 2022, 09:21 -
Capture: VHS-C camera, live, via USB device OR Sony PD150
By tigerdate in forum Capturing and VCRReplies: 2Last Post: 18th Mar 2021, 19:38 -
Out of touch with video capture - USB capture device advice
By Lambchop in forum Capturing and VCRReplies: 7Last Post: 25th Nov 2018, 05:19 -
Device not detected on VHS to USB Capture-Converter
By Anonymous754 in forum Capturing and VCRReplies: 10Last Post: 26th Jun 2017, 07:46
