Hello,
I'm trying to match an audio from a PAL video in 25fps to another video with a framerate of 24/1.001, I used eac3to with the command line "slowdown" and it works pretty well.
The audio format of the first tracks are AC3 192kbps for stereo and 448kbps for 5.1 (I have 2 tracks).
The problem is I will lose quality if I reencode, I would like to limit this loss.
I converted first to flac to add and remove silence between scenes (mostly black transitions) to match the image of the video and after I will reencode to AC3 for compatibility.
As the files are already lossy, can I use the same bitrate to reencode ? Or I have to choose a little above like 320kbps for stereo and 640kbps for 5.1 or maybe another format than AC3. I know that flac is lossless but I would like to keep compatibility with common devices.
The track is mostly talks, no much music.
I used those commands for the stereo track :
and after add/remove silencesCode:eac3to input.ac3 output.flac -slowdown
Code:eac3to input.flac output.ac3 -192
	You could also use clever FFmpeg-GUI for this task.
 It can not only slowdown or speedup any audiotrack, but also adjust the pitch.
 [Attachment 63083 - Click to enlarge]
  Converting 25fps audio to 24fps audio without lowering voice pitchBy killerteengohan in forum AudioReplies: 12Last Post: 14th Apr 2021, 17:21
  29.97 fps to 23.976fps audio with length differentBy ChampaRando in forum Video ConversionReplies: 19Last Post: 26th Nov 2020, 17:10
  how can I batch EAC3To from 25FPS(pal) to 23.976FPS(NTSC)?By aniel in forum AudioReplies: 2Last Post: 5th Feb 2020, 05:02
  [from 50fps to 25fps] vs [directly 25fps]By dira in forum Video ConversionReplies: 1Last Post: 6th Dec 2019, 04:48
  Applied 25fps to 23.9976 slowdown yet audio gets out of sync as video playsBy Snow667 in forum AudioReplies: 2Last Post: 4th Aug 2019, 04:25
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
