I have two Mpeg2 files, both extracted from a DVD (that I don't have anymore). Both files have identical video streams, but each file have different audio streams.
If I want to build a new Mpeg2 file, which contains both of these two audio streams, what is the easiest way to do this? I cannot re-extract anything from the DVD, I only have the aforementioned files to work with. Please if you can include simple, step by step instructions, I would appreciate it.
Use clever Ffmpeg-GUI.
Load the first mpg, click main, click multiplex, click add stream, select the 2nd mpg, unselect the non desired steams, click multiplex. Done.Last edited by ProWo; 25th Jan 2022 at 15:57.
You can use mkvmerge (mkvtoolnix) you will be able to add the 2 video files and select which tracks you want at the end, select the 2 (video + audio) of the first file and only the audio track of the second.
With clever FFmpeg-GUI you have only to set the correct output container (mpg).
[Attachment 63112 - Click to enlarge]
Merging video & audio files
By alwarm in forum Video ConversionReplies: 12Last Post: 17th Sep 2021, 10:14 -
Need help with batch file for merging subpics into multi files
By sailor420 in forum EditingReplies: 1Last Post: 22nd Jun 2021, 22:02 -
Merging all tracks in one - Foobar file shorter duration than Audacity
By jfjfjf in forum AudioReplies: 4Last Post: 10th Feb 2020, 12:06 -
How to replace video & audio streams with other in .ts file?
By VetalSai in forum Video ConversionReplies: 0Last Post: 14th Jul 2019, 09:15 -
FFMpeg merging audio files truncates output to shortest audio file
By Wayneos in forum Video ConversionReplies: 0Last Post: 3rd Jul 2019, 07:07
