I use to use DVDShrink to just Decrypt My DVD Movie Files to My Hard Drive.
Then I use VLC Media Player to Watch them and it works good.
Now with Blue Ray Discs this does not work.
Now I know of a Free Program Called Make MKV but will this Re Compress the Blue Ray Video File and just want it to Decrypt it?
And Yes these are all My DVDs and Blue Ray Discs.
Results 1 to 11 of 11
MakeMKV doesn't compress or alter the quality in any way. It merely wraps the main movie and extra's, if desired in a MKV container. It will do DVD's as well as Blu ray and UHD discs. So basically file size in = file size out and the same for quality. In the case of Blu ray and UHD you can also make a whole disc backup in ISO format.
PS. DVDShrink hasn't been updated since 2004 so there are many newer protection schemes it won't work with.SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
VLC is supposed be able to play Blu-ray with libbluray installed. See https://www.videolan.org/developers/libbluray.html libaacs and libbdplus are needed to decrypt encrypted discs.
You could also try Leawo Blu-ray Player, which is free.
MakeMKV cannot compress anything or convert the original video, audio, and subtitles to different formats. MakeMKV just decrypts and copies all the files and folders on the Blu-ray disc to your hard drive, or muxes the original video, audio, and subtitles into MKV files that it stores on your hard drive. (You must choose to either copy the Blu-ray disc as files and folders or output as MKVs.)Last edited by usually_quiet; 24th Jan 2022 at 23:12.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
And if I Understand You?
If I Copy My Blue Ray Disc to a VOB File it will not Re Compress it? -
If you try to copy your Blu-ray disc to VOB then it probably will be compressed.
VOB is a container associated with DVD and it is only used for standard-definition MPEG-1 and MPEG-2 video. The container file format used for Blu-ray disc copies is M2TS.
Blu-ray video is usually high-definition video and either VC1 or AVC/H.264. Standard definition Blu-ray isn't common. Although MPEG-2 video is allowed for Blu-ray it isn't common either. This means you probably can't copy your Blu-ray to a VOB file without re-sizing and converting the video.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Using the "Save Selected Titles" option, MakeMKV copies the exact same video and audio for those titles that are on the Blu-ray disc to MKVs on your harddrive with no compression whatsoever. MKV files will play just fine with VLC without installing libbluray.
Using the "Backup" option, MakeMKV copies the entire contents of the disc to your hard drive with no compression whatsoever. Individual titles are in M2TS files in the "STREAM" subfolder of the " BDMV" or "BDAV" directory, just like they are on the Blu-ray disc.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
BD3D2MK3D: Convert 3D BDs or MKV to 3D SBS, TAB or FS MKV - Support thread
By r0lZ in forum Blu-ray RippingReplies: 587Last Post: 24th Aug 2026, 08:49 -
DVD copy with Make Mkv-no sound
By ro2124 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jul 2019, 08:39 -
Make MKV?
By gastrof in forum Newbie / General discussionsReplies: 4Last Post: 4th Mar 2019, 23:50 -
How to make exact copy of a mkv/mp4... add subtitles
By jagman911 in forum Video ConversionReplies: 2Last Post: 3rd Dec 2018, 12:29 -
Merging MKV extracted files to playable MKV video file
By deepfrayder in forum EditingReplies: 9Last Post: 12th Dec 2017, 23:17
