Hi,
I have decided to capture each of my VHS videos in a lossless (huffyuv) avi. I am doing this using virtual dub. Should I de-interlace this master before I "lock it away for long term" or shoud I deinterlace it first? My goal is to have the best digital version of the VHS video available for future use, whether it is eventually edited, streamed, authored to DVD etc.
Sorry if this already out there somewhere but, after a couple of hours of digging, I cannot find a clear answer
Thanks!
22west
Keep your archive version as "pure" to the original signal as you can. There will always be better deinterlacers, noise removers, etc. in the future.
Same thinking here. Spend your time and efforts in producing lossless and - as much as possible - flawless interlaced captures of your VHS sources. Means basically avoid dropped frames and other glitches, no clipped or crunched colors (levels) etc. Don't process this captured interlaced "master" footage further for archiving. And continue to keep your VHS tapes and VCR gear (players) in a safe place, they may survive longer than you think - your experience and opinion about the captured quality may also change over time (happened here
Pioneer DVR a new experiment - long term m.2 storage
By jwillis84 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 12th Jan 2020, 00:00 -
Compression for long term storage
By indijay in forum Newbie / General discussionsReplies: 5Last Post: 27th Sep 2019, 11:17 -
Need long term plan! Save my DVDs
By Scott Maze in forum Video ConversionReplies: 3Last Post: 5th Sep 2019, 08:34 -
I Need a Long-Term Media Center Plan. Help!
By dualdivx in forum Media Center PC / MediaCentersReplies: 20Last Post: 26th Jul 2019, 08:29 -
Easiest free way to convert 25fps interlaced to 50fps de-interlaced?
By Gibson's Squares in forum MacReplies: 2Last Post: 25th Jul 2017, 09:06
