I'm wondering if there is any high-quality/transparent proc amps with S-Video that can shift the entire picture over to the right or left a few pixels?
Analog proc amps do not do this. All they do is Luma Black level (usually called "Setup"), Luma White level (aka "White", "Brightness"), Chroma Saturation, and Chroma Hue (aka "Tint", "Phase").
To do that in the analog realm requires a DVE mixer/FX board/box.
Of course "pixels" means nothing in the analog realm anyway.
Scott -
Based on the research I've been doing, it seems like the BVP-4+ is a good proc amp but it has a flaw in that it adds an unremovable vertical line down along the left side of the image that seems to be related to the split screen function. The line is about 16 pixels in or so but in some sources that will actually cover up some of the image. Yes, I know that this can be considered the "overscan" area and all that, but it's still image to me.
For analog sources like VHS that don't really have that much horizontal resolution, is there an analog proc amp that "shrinks" or compresses the image horizontally a little bit so that the leftmost vertical line the BVP-4+ introduces will not overlap with the image. I then then stretch the image back in the digital realm to the proper aspect ratio. -
Bearing in mind that we are talking anlaog TV here, firstly, it IS possible to slightly offset the picture within the screen by stretching, shortening or delaying the horizontal sync pulses but the more it is done, the greater the chances of the timebases misinterpreting the pulses becomes.
I would guess the optimal method to remove this line is to extend the horizontal blanking period. This simply makes the black border on the left side a bit wider but doesn't otherwise change the aspect ratio. As the line should be in the blanking period anyway it would not remove any of the picture at all. Electronically it is fairly simple, just switch the video stream to a black level voltage for a short time after the end of each horizontal sync pulse.
Brian. -
Manually fix pan, shift pixels, with Avisynth
By lordsmurf in forum RestorationReplies: 17Last Post: 19th Dec 2020, 09:34 -
Io Data GV-USB2 V Dub Proc Amp and Histogram
By Alwyn in forum Capturing and VCRReplies: 2Last Post: 6th Oct 2020, 22:37 -
Proc Amp Theory and Practice
By Avagadro1 in forum Capturing and VCRReplies: 11Last Post: 18th Aug 2020, 20:17 -
USB-Live2 Proc Amp Settings in VDub Don't Work
By koberulz in forum Capturing and VCRReplies: 26Last Post: 5th May 2020, 14:44 -
Where to fit a proc amp?
By kodec in forum Capturing and VCRReplies: 13Last Post: 12th Jun 2018, 23:19
