Hi video experts! I've got this 23GB hour long homemade MOV file in 4K res that I'd like to burn to Bluray disc for others to watch in standard players. My computer has a Bluray burner and I've purchased some BD-R discs but can't seem to find a good tutorial on how to convert the MOV file and successfully burn it as a native Bluray disc. My first attempt was to just burn the MOV file to a disc and the Bluray player wouldn't recognize it. Assistance greatly appreciated!
Thanks,
Al
Standard Blu-ray players won't play 4K resolution video files. They also won't play HEVC video, which is often used for 4K. For best compatibility with Blu-ray players, you need to re-encode the video and audio to match the Blu-ray standard and author a Blu-ray disc.
If you are using Windows, you should post the MediaInfo report for the 4K MOV file that you want to convert. (Open the file with MediaInfo. Click on "View" and "Text". Copy the text from the window and paste into a new post here.) That way perhaps someone can suggest a good method for converting your file for Blu-ray.
If you use a Mac, use the Report function and ask a moderator to move your post to the Mac forum so you can get help from other Mac users.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Thanks for the reply. Here is the text output from the MediaInfo tool:
General
Complete name : D:\My Media\Wedding\Video\Wedding_Final.mov
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 0000.00 (qt )
File size : 23.2 GiB
Duration : 1 h 6 min
Overall bit rate : 49.9 Mb/s
Movie name : sample
Description : This video is about sample
Encoded date : UTC 2021-12-20 23:56:17
Tagged date : UTC 2021-12-21 00:38:30
Writing library : Apple QuickTime
com.apple.quicktime.keywords : Wedding
com.apple.quicktime.author : John Doe
com.apple.quicktime.title : sample
Video
Format : AVC
Format profile : High@L5.1
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 2 frames
Format settings, GOP : M=2, N=12
Codec ID : avc1
Bit rate mode : Variable
Bit rate : 49.7 Mb/s
Maximum bit rate : 768 kb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.250
Stream size : 23.1 GiB (99%)
Title : Core Media Video
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Source duration : 1 h 6 min
Bit rate mode : Constant
Bit rate : 119 kb/s
Nominal bit rate : 128 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 56.4 MiB (0%)
Source stream size : 56.4 MiB (0%)
Title : Core Media Audio
Other
Type : Time code
Format : QuickTime TC
Time code of first frame : 00:00:00:00
Time code, striped : Yes
Title : Core Media Time Code
I found a short demo clip in a MOV file online that I could download to test paid consumer Blu-ray authoring software. The file has characteristics close enough to yours for test purposes.
I downloaded the trial of TMPGEnc Authoring Works 6 to see if it could handle authoring a 1080p Blu-ray from a UHD source. It produced a decent result and was reasonably easy to use. ...but if you need to buy the full version for your project it's about $100.Format : MPEG-4
File size : 113 MiB
Duration : 18 s 547 ms
Overall bit rate : 51.2 Mb/s
Encoded date : UTC 2016-01-30 17:46:24
Tagged date : UTC 2016-01-30 17:46:43
com.apple.quicktime.location.ISO6709 : +33.9173-084.0055+294.114/
com.apple.quicktime.make : Apple
com.apple.quicktime.model : iPhone 6s
com.apple.quicktime.software : 9.2.1
com.apple.quicktime.creationdate : 2016-01-30T12:46:24-0500
Video
Format : AVC
Format settings : CABAC / 1 Ref Frames
Format settings, Reference frames : 1 frame
Format settings, GOP : M=1, N=30
Codec ID : avc1
Bit rate : 51.1 Mb/s
Frame rate mode : Variable
Frame rate : 29.970 (29970/1000) FPS
Minimum frame rate : 28.571 FPS
Maximum frame rate : 30.000 FPS
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.206
Stream size : 113 MiB (100%)
Metas : 3,4
Audio
Format : AAC LC
Source duration : 18 s 599 ms
Bit rate : 86.9 kb/s
Channel(s) : 1 channel
Channel layout : C
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Stream size : 197 KiB (0%)
Source stream size : 197 KiB (0%)
I have no doubt that there is freeware that could be used to do the job. Unfortunately, I don't have enough experience to write a script to re-encode your MOV file with the right specs for 1080p Blu-ray. tsmuxer can produce a menu-less Blu-ray from Blu-ray-compliant audio and video input. Blu-Disc Studio Lite can also create Blu-ray files and folders from compliant sources but requires a fair amount of knowledge to use.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Thanks @usually_quiet! I tried TMPGEnc Authoring Works and it worked quite well for my needs. Easy to use and did the conversion and burning. I guess we'll have to live with 1080P discs vs 4K but I'm willing to do that.
bluray disc from folder to iso And a picture in the virtual disc icon
By CapricornX10X in forum Blu-ray RippingReplies: 3Last Post: 27th Jan 2020, 12:01 -
Convert ProRes .mov file to Bluray m2ts
By Rajesh Singh in forum Authoring (Blu-ray)Replies: 1Last Post: 1st May 2019, 14:54 -
Ripping Episodes from my Bluray-Disc
By JonNada in forum Blu-ray RippingReplies: 1Last Post: 2nd Jan 2018, 01:20 -
Why bluray player doesn't read the bluray disc?
By mastersab in forum DVD & Blu-ray WritersReplies: 5Last Post: 31st Dec 2017, 07:12 -
Bluray Mkv to normal bluray disc
By Igniz in forum Video ConversionReplies: 3Last Post: 10th May 2017, 22:15
