I have 10 video files (no audio) ts format and an equivalent number of audio files (also with ts extension) which i need to mux into 10 files in a BATCH operation. Ts muxer is great but i cannot do so in batches and avidemux does not let me 'pickup the audio file with ts extension
Please suggest what i may do as this is a frequent operation for me
Of course you can batch with tsmuxer, you can also use ffmpeg for muxing (but i have less trust in ffmpeg muxer than in tsmuxer).
Code:tsMuxeR version git-938eefb. github.com/justdan96/tsMuxer tsMuxeR is a simple program to mux video to TS/M2TS files or create BD disks. tsMuxeR does not use external filters (codecs). Examples: tsMuxeR <media file name> tsMuxeR <meta file name> <out file/dir name> tsMuxeR can be run in track detection mode or muxing mode. If tsMuxeR is run with only one argument, then the program displays track information required to construct a meta file. When running with two arguments, tsMuxeR starts the muxing or demuxing process. Meta file format: File MUST have the .meta extension and be encoded in UTF-8 (but see README.md). This file defines the files you want to multiplex. The first line of a meta file contains additional parameters that apply to all tracks. In this case the first line should begin with the word MUXOPT. The following lines form a list of tracks and their parameters. The format is as follows: <code name>, <file name>, <parameters> Parameters are separated with commas, with each parameter consisting of a name and a value, separated with an equals sign. Example of META file: MUXOPT --blu-ray V_MPEG4/ISO/AVC, D:/media/test/stream.h264, fps=25 A_AC3, D:/media/test/stream.ac3, timeshift=-10000ms In this example one AC3 audio stream and one H264 video stream are multiplexed into BD disc. The input file name can reference an elementary stream or a track located inside a container. Supported input containers: - TS/M2TS/MTS - EVO/VOB/MPG/MPEG - MKV - MOV/MP4 - MPLS (Blu-ray media play list file) Names of codecs in the meta file: - V_MPEGI/ISO/VVC H.266/VVC - V_MPEGH/ISO/HEVC H.265/HEVC - V_MPEG4/ISO/AVC H.264/AVC - V_MPEG4/ISO/MVC H.264/MVC - V_MS/VFW/WVC1 VC1 - V_MPEG-2 MPEG2 - A_AC3 AC3/AC3+/TRUE-HD - A_AAC AAC - A_DTS DTS/DTS-Express/DTS-HD - A_MP3 MPEG audio layer 1/2/3 - A_LPCM raw pcm data or PCM WAV file - S_HDMV/PGS Presentation graphic stream (BD subtitle format) - S_TEXT/UTF8 SRT subtitle format. Encoding MUST be UTF-8/UTF-16/UTF-32 Each track may have additional parameters. Track parameters do not have dashes. If a parameter's value consists of several words, it must be enclosed in quotes. Common additional parameters for any type of track: - track track number if input file is a container. - lang track language. MUST contain exactly 3 letters. Additional parameters for audio tracks: - timeshift Shift audio track by the given number of milliseconds. Can be negative. - down-to-dts Available only for DTS-HD tracks. Filter out HD part. - down-to-ac3 Available only for TRUE-HD tracks. Filter out HD part. - secondary Mux as secondary audio. Available for DD+ and DTS-Express. - default Mark this track as the default when muxing to Blu-ray. Additional parameters for video tracks: - fps The number of frames per second. If not defined, the value is auto detected if available in the source stream. If not, it defaults to 23.976. - delPulldown Remove pulldown from the track, if it exists. If the pulldown is present, the FPS value is changed from 30 to 24. - ar Override video aspect ratio. 16:9, 4:3 e.t.c. Additional parameters for H.264 video tracks: - level Overwrite the level in the H264 stream. Do note that this option only updates the headers and does not reencode the stream, which may not meet the requirements for a lower level. - insertSEI If the original stream does not contain SEI picture timing, SEI buffering period or VUI parameters, add this data to the stream. This option is recommended for BD muxing. - forceSEI Add SEI picture timing, buffering period and VUI parameters to the stream and rebuild this data if it already exists. - contSPS If the original video doesn't contain repetitive SPS/PPS, then SPS/PPS will be added to the stream before each key frame. This option is recommended for BD muxing. - subTrack Used for combined AVC/MVC tracks only. TsMuxeR always demultiplexes such tracks to separate AVC and MVC streams. Setting this to 1 sets the reference to the AVC part, while 2 sets it to the MVC part. - secondary Mux as secondary video (PIP). - pipCorner Corner for PIP video. Allowed values: "TopLeft","TopRight", "BottomRight", "BottomLeft". - pipHOffset PIP window horizontal offset from the corner in pixels. - pipVOffset PIP window vertical offset from the corner in pixels. - pipScale PIP window scale factor. Allowed values: "1", "1/2", "1/4", "1.5", "fullScreen". - pipLumma Allow the PIP window to be transparent. Transparent colors are lumma colors in range [0..pipLumma]. Additional parameters for PG and SRT tracks: - video-width The width of the video in pixels. - video-height The height of the video in pixels. - default Mark this track as the default when muxing to Blu-ray. Allowed values are "all" which causes all subtitles to be shown, and "forced" which shows only elements marked as "forced" in the subtitle stream. - fps Video fps. It is recommended to define this parameter in order to enable more careful timing processing. - 3d-plane Defines the number of the '3D offset track' which is placed inside the MVC track. Each message has an individual 3D offset. This information is stored inside 3D offset track. Additional parameters for SRT tracks: - font-name Font name to render. - font-color Font color, defined as a hexadecimal or decimal number. 24-bit long numbers (for instance 0xFF00FF) define RGB components, while 32-bit long ones (for instance 0x80FF00FF) define ARGB components. - font-size Font size in pixels. - font-italic Italic display text. - font-bold Bold display text. - font-underline Underlined text. - font-strikeout Strikethrough text. - bottom-offset Distance from the lower edge while displaying text. - font-border Outline width. - fadein-time Time in ms for smooth subtitle appearance. - fadeout-time Time in ms for smooth subtitle disappearance. - line-spacing Interval between subtitle lines. Default value is 1.0. tsMuxeR supports additional tags inside SRT tracks. The syntax and parameters coincide with HTML: <b>, <i>, <u>, <strike>, <font>. Default relative font size (used in these tags) is 3. For example: <b><font size=5 color="deepskyblue" name="Arial"><u>Test</u> <font size= 4 color="#806040">colored</font>text</font> </b> Global additional parameters are placed in the first line of the META file, which must begin with the MUXOPT token. All parameters in this group start with two dashes: --pcr-on-video-pid Do not allocate a separate PID for PCR and use the existing video PID. --new-audio-pes Use bytes 0xfd instead of 0xbd for AC3, True-HD, DTS and DTS-HD. Activated automatically for BD muxing. --hdmv-descriptors Use HDMV descriptors instead of ITU-T H.222.0 | ISO/IEC 13818-1 descriptors. Activated automatically for BD muxing. --vbr Use variable bitrate. --minbitrate Sets the lower limit of the VBR bitrate. If the stream has a smaller bitrate, NULL packets will be inserted to compensate. --maxbitrate The upper limit of the vbr bitrate. --cbr Muxing mode with a fixed bitrate. --vbr and --cbr must not be used together. --vbv-len The length of the virtual buffer in milliseconds. The default value is 500. Typically, this option is used together with --cbr. The parameter is similar to the value of vbv-buffer-size in the x264 codec, but defined in milliseconds instead of kbit. --no-asyncio Do not create a separate thread for writing. This option also disables the FILE_FLAG_NO_BUFFERING flag on Windows when writing. This option is deprecated. --auto-chapters Insert a chapter every <n> minutes. Used only in BD/AVCHD mode. --custom-chapters A semicolon delimited list of hh:mm:ss.zzz strings, representing the chapters' start times. --demux Run in demux mode : the selected audio and video tracks are stored as separate files. The output name must be a folder name. All selected effects (such as changing the level of a H264 stream) are processed. When demuxing, certain types of tracks are always changed : - Subtitles in a Presentation Graphic Stream are converted into sup format. - PCM audio is saved as WAV files. --blu-ray Mux as a BD disc. If the output file name is a folder, a Blu-Ray folder structure is created inside that folder. SSIF files for BD3D discs are not created in this case. If the output name has an .iso extension, then the disc is created directly as an image file. --blu-ray-v3 As above - except mux to UHD BD discs. --avchd Mux to AVCHD disc. --cut-start Trim the beginning of the file. The value should be followed by the time unit : "ms" (milliseconds), "s" (seconds) or "min" (minutes). --cut-end Trim the end of the file. Same rules as --cut-start apply. --split-duration Split the output into several files, with each of them being <n> seconds long. --split-size Split the output into several files, with each of them having a given maximum size. KB, KiB, MB, MiB, GB and GiB are accepted as size units. --right-eye Use base video stream for right eye. Used for 3DBD only. --start-time Timestamp of the first video frame. May be defined as 45Khz clock (just a number) or as time in hh:mm:ss.zzz format. --mplsOffset The number of the first MPLS file. Used for BD disc mode. --m2tsOffset The number of the first M2TS file. Used for BD disc mode. --insertBlankPL Add an additional short playlist. Used for cropped video muxed to BD disc. --blankOffset Blank playlist number. --label Disk label when muxing to ISO. --extra-iso-space Allocate extra space in 64K units for ISO metadata (file and directory names). Normally, tsMuxeR allocates this space automatically, but if split condition generates a lot of small files, it may be required to define extra space. --constant-iso-hdr Generates an ISO header that does not depend on the program version or the current time. Not meant for normal usage.
Batch Mux Audio+Video in ffmpeg .... possible ?
By DonSeenu in forum Video ConversionReplies: 2Last Post: 19th Aug 2021, 11:15 -
Mux audio and Video in Mkvmerge using Batch File
By Daringbaaz in forum Newbie / General discussionsReplies: 2Last Post: 18th Oct 2019, 04:30 -
How can i edit this script to batch mux chapters with MkvToolsNix
By Red_Rain77 in forum Newbie / General discussionsReplies: 0Last Post: 25th Aug 2019, 20:20 -
how can i mux cc with video and audio?
By tianhanghai in forum SubtitleReplies: 0Last Post: 28th Feb 2018, 21:13 -
MP4Box command to batch MUX MP4s
By jd185051 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Apr 2017, 10:43
