Hi, when converting interlaced videos, FFmpeg maintains the interlacing and field order correctly, but the resulting file does not indicate the type of interlacing clearly.
I have read that x264 only uses MBAFF. So we have a problem when we want to edit that transcoded video in Edius 9 and 10, because it marks the video as progressive (can be changed manually).
So for example FFmpeg gives this information about the original file:
field_order=tt
but in the transcoded file:
field_order=unknown
although using IDET detects TFF correctly:
[Parsed_idet_0 @ 0000000005b8fc80] Multi frame detection: TFF: 312 BFF: 0 Progressive: 0 Undetermined: 0
Using Mediainfo on the original:
"ScanType": "Interlaced",
"ScanOrder": "TFF",
but in the transcoded:
"ScanType": "MBAFF",
"ScanOrder": "TFF",
So Edius must mess with that and mark that video as progressive on load. It seems to ignore MBAFF or it doesn't find any field order data.
So my question is is there a way to include "field_order" or some other field in the transcoded video so that Edius can identify the field order correctly?
The command I use to convert the videos is this:
-y -hide_banner -threads 0 -hwaccel dxva2 -i SOURCEFILE -vcodec libx264 -profile:v high -level 4.1 -preset slow -b:v 10000k -maxrate 10000k -bufsize 20000k -flags +ilme+ildct -alternate_scan 1 -top 1 -g 50 -codec aac -b:a 192k -ar 44100 -movflags +faststart DESTINATIONFILE
how to force ffmpeg to encode mpeg2 interlaced ?
By hydra3333 in forum Video ConversionReplies: 19Last Post: 25th Jun 2021, 08:22 -
Problem re-encoding MBAFF
By mugz8391 in forum Video ConversionReplies: 9Last Post: 26th Mar 2021, 21:29 -
FFMPEG Not Flagging Interlaced Video Properly
By ENunn in forum Video ConversionReplies: 3Last Post: 21st Jan 2021, 13:28 -
ffmpeg changes interlaced to progressive
By SF01 in forum Video ConversionReplies: 12Last Post: 30th Mar 2020, 10:51 -
How to keep interlaced footage interlaced converting from AVI to MP4?
By kodec in forum Video ConversionReplies: 23Last Post: 1st Jul 2019, 10:36
