Hi,
How can I improve visual quality of Dissolve transitions between still images with libx264 in FFmpeg? It's not bad, but I can see artefacts of a compression.
Also banding may appear on a gradient of a blue sky.
I use the following options: -refs 4 -bf 3 -g 250 -crf 22
So it is a slideshow?
I recommend 0 b-frames and a short gop (maximum = 5 seconds). Also, 10-bits instead of 8-bits.
There exist some custom builds of x264 which use the famous "fade compensation patch", you might want to give them a try.
"Programmers are human-shaped machines that transform alcohol into bugs." -
Many thanks for your advices! I'll experiment with these settings and will try to find that patch for x264
[Linux] ffmpeg libx264 VS [Windows] x264: quality difference ?
By precipizio in forum Video ConversionReplies: 1Last Post: 4th Aug 2021, 04:05 -
Cannot encode video with ffmpeg libx264 maintaining 5 reference frames.
By Budman1 in forum EditingReplies: 4Last Post: 20th Aug 2020, 14:27 -
How do I use Dissolve with one clip?
By smike in forum EditingReplies: 1Last Post: 20th May 2020, 23:26 -
libx264 is no longer available in ffmpeg?
By oduodui in forum LinuxReplies: 2Last Post: 17th Feb 2019, 14:49 -
libx264 warning
By SameSelf in forum Video ConversionReplies: 5Last Post: 27th Jun 2017, 15:02
