I'm at a loss guys, I have never had this problem before until few weeks ago on both Win 7 and Win 10 machines at around the same period of time, Basically the problem is when I input a script from AvsPmod and export to vdub I usually select the right field order for PAL and NTSC accordingly in the script, I can no longer get vdub to follow the field order, no matter what I put after QTGMC, Here is the basic script I'm using:
oln just sent me a capture and the initial AVI interlaced file doesn't seem to have any problems, Only the exported de-interlaced file doesn't follow the field order, Attached samples for using both BFF and TFF on the same file, Is this a vdub problem, does removing it and re-installing will clear this problem? I'm pretty sure I've done something stupid otherwise the problem would not have duplicated itself on the other machine.Code:AviSource("C:\Users\Folder\file.avi") QTGMC(Preset="Faster") AssumeTFF()
Puta, Good catch PDR
I knew I did something stupid
Subtitle styles not working properly
By Kracov in forum SubtitleReplies: 2Last Post: 3rd Dec 2021, 08:29 -
Cannot properly IVTC
By ZetaStax in forum Video ConversionReplies: 13Last Post: 17th Oct 2019, 17:08 -
M3u8 channels not working in Samsoung smart tv but working in vlc player
By alaasl3 in forum Video Streaming DownloadingReplies: 18Last Post: 15th Apr 2019, 03:47 -
Procoder 2 Not Working Properly?
By meeshu in forum Newbie / General discussionsReplies: 14Last Post: 14th Apr 2019, 19:37 -
Mounting on File Not Working Properly
By jealousy91 in forum Video ConversionReplies: 15Last Post: 10th Feb 2019, 19:20
