I have a movie ,i wanna know it encoded using which preset
Presets like...ultrafast, fast, medium, slow, placebo etc.
Anonymous543Guest
I encoded a short test clip using each of the x264 presets then used MediaInfo to build the table in this post:
https://forum.videohelp.com/threads/395184-Need-help-downloading-this-vimeo-with-youtu...dl#post2567538
subme can be used an indicator for the preset. But one can modify individual settings so that won't always be accurate.
You can do the same for other codecs that store the settings in the metadata.
XMedia Recode - Video Tab - "Preset" Setting
By Cherry Picker in forum Video ConversionReplies: 0Last Post: 28th Dec 2021, 10:55 -
Find out which ffmpeg version encoded the video
By Johanna12221 in forum EditingReplies: 3Last Post: 21st Dec 2021, 07:20 -
Does setting the ffmpeg -preset affect quality? Does Handbrake preset?
By LaserBones in forum Newbie / General discussionsReplies: 7Last Post: 15th Jul 2020, 13:01 -
Matroska with improperly encoded video
By zhenya_hacker in forum Newbie / General discussionsReplies: 30Last Post: 21st Jun 2017, 20:05 -
Fixing 24p video encoded as 30p
By Luke M in forum Video ConversionReplies: 3Last Post: 24th Apr 2017, 11:28
