  1. what is the minimum suitable bitrate for AC3 audio? is 256kbps is good enough? i want to convert some bluray movie DTS audio to AC3 without losing much data.
  2. Minimum bitrate for AC3 5.1 is 384kbps, recommended is 448kbps or better, up to 640kbps.
    DVDs have 384kbps and 448kbps for AC3 5.1 - 256kbps is only suited for Stereo.
    For best quality you should convert to 640kpbs.
  3. Member Skiller's Avatar
    Oct 2013
    Germany
    256 Kbit/s is way too low for 5.1 AC3 to sound acceptable.
    I agree 384 KBit/s is about the minimum you may use, but better go higher if you can.
    Note that for DVD 448 is the maximum allowed; 640 is not DVD compliant (although it should work fine in almost all cases anyway).
  4. Originally Posted by firekid View Post
    Transcoding from DTS to AC-3 may be sub-optimal (never found deeptrough analysis how DTS artifacts will affect DCT based codecs) - in your case i would do some tests and will try to find some sweet spot between bitrate and quality - it should be quite fast - ffmpeg and simple script should be fine.
    Afraid that there is no free (open source) AC-3 codec capable to provide quality (VBR) focused encoding - you may try to reduce bandwidth (low pass) in FC + surround channels - this may help in bitrate allocation for both Front channels so perhaps 256...320kbps will be quality acceptable.
  5. thank you all, i think i will use 448.
  6. Anonymous
    Guest
    Oct 2018
    Scotland
    Searched google for the same question and was brought here! Bumped for future refrence
  8. Originally Posted by bar72 View Post
    You can add also this thread https://forum.videohelp.com/threads/409055-Minimum-AC3-Bitrate-for-5-1-Stereo
    Dolby Labs declaring 64Kbps as usually enough for channel.
