I was generating a video encoded in PCM audio from a wav audio file using the PCM Coder script and I found out that MPC-HC plays the videos with sound although there is no audio track in the video, Not sure if k-lite codec making this possible or just a feature that you won't find out about unless you try it, or the PCM coder generates a tag for the MPC-HC to playback the video with audio. So far none of the famous media players I tried have been able to playback audio for that videos including VLC and Windows media player.
The video files generated are huge because it uses lossless AVI in full broadcast NTSC standard 525 lines (720x525), I've attached a sample of 22 seconds @ 366MB. I know, those files are intended to be recorded on a VHS tape or similar format as video using a hardware PCM encoder, This is just a fun experiment.
	Probably there is a "Kylie Minogue - Je Ne Sais Pas Pourquoi.WAV" file in the same directory and you just didn't notice it.
 I mean: goto "Options" --> "Playback" --> "Auto-load audio files".Last edited by El Heggunte; 17th Jan 2022 at 04:56. Reason: clarity "Programmers are human-shaped machines that transform alcohol into bugs."
	You're right I deleted the wav file and MPC-HC can no longer playback the audio in the video file, What a bummer ! I'm glad the mistery is solved.
  Subtitle is Hidden.. Why?By maczones in forum SubtitleReplies: 2Last Post: 30th Oct 2021, 20:16
  Comparing MPC-HC vs MPC-BEBy vhwul62 in forum Software PlayingReplies: 10Last Post: 9th Jan 2021, 08:13
  sync offset and jitter values in mpc-hc and mpc-beBy Milardo in forum Capturing and VCRReplies: 0Last Post: 16th Nov 2020, 19:29
  Feature request for mpc-hc & mpc-beBy babai89 in forum Software PlayingReplies: 5Last Post: 9th Aug 2017, 19:37
  Media Player Classic / MPC-BE / MPC-HC : differences between themBy devilcoelhodog in forum Software PlayingReplies: 19Last Post: 25th Jun 2017, 18:54
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
