Hello,
I want to know if its possible (with a workaround) to control de proc amp settings of the capture card in virtualdub via a "control surface" (a joystick with joytokey...) without launching the windows of this option in virtualdub.
What I want to do, is having a joystick that can let me color correct the capture before launching it.
If not, is there a capture card that can control the brightness, contrast, rgb independently of virtual dub?
https://joytokey.net/en/
Well Im using a soft called "Crossbar Thing" and it launch in the same time that virtualdub with a bat file,
my problem now is to know if in windows, is it possible to control options of any software via keyboard, like creating my own shortcut for any option, but I dont think its possible. -
So you're using Graph Edit or Graph Studio Next to bring up crossbar filter and proc amp? You should be able to left click on any of the proc amp sliders then use the keyboard to adjust it while VirtualDub is capturing/previewing.
Thanks for the answer,
in short, what I'm looking to do is to control parameters accessible in virtualdub via the keyboard or a joystick without having to open any option window.
In music softwares, there is often the midi learn option which allows to assign any midi signal to a physical controller, I'm looking to do something similar...
First foray in colour correcting/grading Kodachrome 16mm film
By Dutchsteammachine in forum RestorationReplies: 22Last Post: 18th May 2021, 15:23 -
Premiere Pro Replacing Color
By DunnoNo in forum EditingReplies: 3Last Post: 17th Jan 2021, 19:55 -
newbie to AVISynth & VirtualDub-need help with IVTC & deinterlace via QTGMC
By clashradio in forum Capturing and VCRReplies: 79Last Post: 14th Nov 2018, 20:05 -
Color corrections in VirtualDub
By GovertdeKat in forum RestorationReplies: 20Last Post: 7th Jan 2018, 10:47 -
ffmpeg plugin for VirtualDub: is there a way to open alwais in BT601 color?
By marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 10th Mar 2017, 03:09
