Hello everyone,
I'm new to the forum but I've been editing videos for years. I'd always used Sony Vegas, but started using Adobe Premiere Pro CC v12.0 only a couple of years ago, and it has almost always worked flawlessly.
Since a couple of months though, I've started experiencing strange issues while editing:
- Whenever I move the slider in the timeline, the preview is not responsive at all, and I have to wait at least 3 seconds for the proper frame to appear in the preview; the same delay happens whenever I click the "play" button (I have to wait 3 seconds before the preview starts playing);
- At the beginning of these 3 seconds, I noticed 100% CPU activity spikes in the task manager;
- If I try to edit too fast (cuts, trims, move clips, every other action), the chances of the software to crash are almost 90%... I've been editing a 45 min video project and probably I've run into hundreds of crashes. It just freezes and I have to kill the process in the task manager.
I'm thinking that the crash is caused by the first issue: in fact, I've noticed that if I wait for the preview to load (3 seconds after I stop moving the slider), PP will never crash. The crashes only occurs if actions are made in those 3 seconds of pre-loading.
I'm sure that months ago the software was not so sluggish. I've tryed with the following fixes:
- Clear media cache files
- Reset workspaces
- Disable GPU acceleration
- Reduce the preview size
- Converting all of the footages I'm working with into GoPro Cineform codec using shutter encoder
None of this solved the problem... The conversion into Cineform helped a lot in the first stages of the project (faster video playback and editing, less crashes), but as soon as it started becoming bigger, I got the same bug again.
Are there any other things I could try? Is it possible that the "Essential audio" tool in the "Audio" workspace is causing the issue? I used it a lot to correct the audio levels.
EDIT: the strange thing is that if I hold the slider with the left click, after those 3 seconds, the preview starts to be 100% responsive (I can see the video frames updating in real time when moving the slider).
System Specs:
- CPU: Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.19 GHz
- GPU: NVIDIA GeForce GTX 1060 6 GB
- RAM: 16 GB
Footage Specs:
- Container: MPEG-4 (JVT)
- Codec: avc1 (avc1/isom)
- Acquired with DJI Osmo Pocket and DJI Mavic Mini
Thanks in advance for the help!
It turned out that Essential sounds was the cause of the lag! In fact, if I delete all of the audio tracks, everything goes instantly super fast.
Do you know how can I use essential sounds without encountering this issue? Have newer versions of Premiere solved it?
Not able to render timeline in adobe premiere pro
By Robbson321 in forum EditingReplies: 0Last Post: 10th Apr 2021, 02:48 -
Vsdc editing on timeline: locking scenes together
By cellojojo in forum EditingReplies: 1Last Post: 19th Nov 2020, 09:12 -
New System has playback staggering when editing in Premiere Pro - Any Ideas
By RokkoRokko in forum ComputerReplies: 0Last Post: 30th Oct 2020, 23:38 -
Process for Ripping DVDs for Editing in Premiere Pro?
By GothPanda in forum DVD RippingReplies: 2Last Post: 17th Dec 2017, 22:47 -
Hello everyone. Laptop for 4k editing on premiere pro without proxies?
By John1 in forum EditingReplies: 5Last Post: 6th May 2017, 16:19
